You could have a bad spot on the flywheel. The flywheel is a plate with a ring of teeth the gear on the starter engages. If you turn the crankshaft a few inches and the starter works, I would check the flywheel.
Otherwise, it could be a mounting problem with the starter, or something keeping the bendix gear from engaging.
SOURCE: Have 94 ram 1500 replaced starter and
are you sure you got the wires back on tight? Also it sounds like the bendex is not kicking out like it is supose to.....Did you change the starter cylenoied?
even some new starters are bad, it doesent happen much but it does happen. You might even take the starter back out and run Jumper cables to the starter. See if the bendex will kick out and stay out untial you diconect the starter......Sorry for your run of bad luck and I hope this is of some help.
