Question about Panasonic AG-HVX200A Mini DV Camcorder
Dub from P2 card to tape
 It seems I'm close but there's is a few missing steps I need to dub from the P2 cards to the internal tape deck.
What are the steps?
Thanks!
Click onto tape mode then press the camera/view button at the back keep your finger on it for 10 seconds till it goes to pc (red) , then press the tumbnail button on the top of the camera then press record . that should do it.
Posted on Dec 30, 2008
I get a ''not permitted' symbol when i push the dubbing button
You are no doubt trying to copy a commercially released tape--which has a built-in copy protecting coding, preventing duplication. You can only copy home-made tapes!
Jul 31, 2012 | Televison & Video
How do I transfer a video from vcr to dvd on magnavok dvd/vcr recorder ?
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
(only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
Oct 27, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Sony DCR-TRV 340 Digital Camcorder. Self Diagnosis display with code: C:32:11 Followed steps in manual, but still showinng the code. What does the C:32:11 mean?
means its a stuck tape tray or stuck open. But it actually can be one of a few parts on the tape tray. Sony actually wont give out information on this error cause there are so many failures. There are many people however that figured out how to fix this. Its actually a very big problem with sonys and ranges in 300-500$usd to get fixed by sony unless under warranty.
i believe these are the parts that you would need
Here's the part #39;s for mode gear & whole chassis,
Mode gear : X20244611
$4.80
Whole Chassis excluding Drum : A1437006A
$54
Sony Parts: 800-488-7669
and here is a video on someone repairing there sony camera with the same problem.
if you need further assistance i will be here to help you, thank you and good luck.
Aug 17, 2010 | Sony Cameras
Hi. I own a HVX200A...and since yestarday I'm having issues when in P2 mode. tape mode works fine but if turn on in P2 mode.. i get the 1&2 P2 slots sign on the LCD blinking non stop, can't access...
Wow I have not any ideas on all these problems, all I do know is if it was my camera I would remove the power-pack and do complete reset, that sorts them all out no problem.
David UK
Jun 25, 2010 | Panasonic AG-HVX200A Mini DV Camcorder
What are the steps to dubbing off the other tape?
You need a set of RCA AV dubbing cables (available at fine electronics stores everywhere), and a couple VCRs. Plug the cables into the "A/V Out" jacks on the back of the VCR that will be playing, and into the "A/V In" jacks on the VCR that will record.
Also on the recording VCR, use a regular coaxial cable to attach it to a television.
Now, set the TV to 3, fire up the VCR's, and set the recording VCR's TV/VCR toggle to VCR. Also on the one that is recording, set the channel to "INPUT" or "AUX" or something like that. (You're telling it to record what it sees coming from the jacks you plugged the cables into.) Then hit Play on the other machine. You should be able to see your tape playing back. If you do, you have followed these directions correctly, and you're ready to make your dub.
HINT: The first few feet of tape are often prone to dropout and generally sucking. Record a minute of black before making your dub. Mark this on the tape or tell them when you turn it in. They will be impressed.
May 28, 2010 | Sony DTC-ZE700 Dual Cassette Deck
Transfer from pz card shot on HD to mini DV tape
you can transfer to DV tape only by using software like Edius 6 or a similar one.
First you download the p2 card on the hard drive and then you use this program to convert the video file to DV and use the camcorder as recorder connecting to pc via firewire .
Jan 22, 2010 | Panasonic AG-HVX200A Mini DV Camcorder
VHS TO DVD DUB ERROR ON PLAYBACK
Sounds like the DVD is not finalizing or not doing so properly. Check your setup options...
Mar 30, 2008 | Sony RDR-VX555
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Dubbing from VHS to DVD
Below is the .pdf link for the users manual for this machine.
http://books.jvcservice.com/Download/1016461904/LPT0952-001B.pdf
On page 63 of the .pdf is the page titled "Manual Dubbing (From VCR to DVD)" that will walk you step by step through the process to accomplish what you want to do.
Aug 31, 2007 | JVC DR-MV1SU DVD Recorder/VCR
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Panasonic AG-HVX200A Mini DV Camcorder Logo
325 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
