Question about Acer Computers & Internet
The media soft keys dont work and the scroll button doesnt work either
  • 68 Answers
Have you installed the drivers? Windows will not automatically recognise the extra keys on your keyboard
Posted on Dec 20, 2008
How to turn off text clicking
REDUCING KEYPAD VOLUME
STEP 1 Press the phone's menu key, located between the two soft keys on the top of its keypad.
STEP 2 Scroll to "Settings" and press the center key to select it.
STEP 3 Scroll to "Ring Styles," press the center key, scroll to the specific ring profile that you are using and press the center key to select it.
STEP 4 Scroll to "Key Volume," select it by pressing the center button, turn the volume all the way down and press the center button to lock your changes.
STEP 5 Press the soft key labeled "Exit" to exit the menu system.
STEP 6 Repeat this process for every ring profile in which you want the keypad not to make sound when you use it.
Mark
Motorola Support
May 09, 2014 | Motorola Mobility RAZR V3
We bought KX-TG4024 cordless telephones. Can the ring tone be changed?
I have a similar model and the ring tone can be changed.
To change on the Handset
1, Press Menu
2, Scroll using arrow up/down key- go to "Ringer setting" then press soft key Select.
3, Scroll to "Incoming call" then press soft key Select
4, You can scroll to "ON/OFF or 2".. Maybe your phone has more choices. Number 2 will be a different ring tone.
5, Press soft key "Save" then press OFF key.
The Base Unit
1, Press Menu
2, Scroll using up/down arrow keys to "Initial setting" press soft key Select
3, Srcoll to "Set base unit" press soft key Select
4, Scroll to "Incoming call" press soft key Select
5, select ON/OFF or 2 with arrow keys
6, Press soft key "Save" then press OFF key.
I hope this has been helpful..
Aug 29, 2011 | Panasonic Cell Phones
I want to make my phone touch tone
I presume you want to use tone dialling..If that is the case the solution should be same as my phone.. Press Menu then scroll using up/down arrow key to "Initial setting" and press(soft key) Select, then scroll to "set tel line" press(soft key) select, then scroll to "Set Dial mode" press(soft key) Select, then scroll to "Tone" , then press(soft key) Save then press Off button.**This is done via handset**Soft keys are the ones under screen*** I hope this has been helpful.
Aug 25, 2011 | Panasonic KX-TG2313 Cordless Phone
I would convert an french my samsung e250
Follow this steps,
1. Press the "Menu" button, or select the "Menu" option, on your Samsung phone. Your phone menu will now appear.
  1. 2.Scroll through the menu using the directional pad and highlight the "Settings" option. Press the button in the center of the directional pad to continue.
    3. Scroll to the "Phone" option and press the middle button. Then scroll to the "Language" option and press the middle button. The phone will now show two fields: "Screen text" and "Input language."
    4. Scroll to the "Screen text" field and press the soft key under the word "Change." A list of the available languages will now appear in a drop-down box. On Samsung phones that use a SIM card, an available option is called "Automatic," which will default the phone to the language of the SIM card.
    5. Scroll to the language you want and press the "OK" button.
    6. Highlight the "Input language" field and press the "Change" soft key. Scroll to the language you want and press the "OK" button.
    7.Press the soft key under the word "Save" to save your changes and return to the phone settings menu.
Nov 23, 2010 | Samsung SGHE250i Cell Phone
How do i alter the sound when i send a text message
From the stand by screen press the "Menu" key.
Scroll to Settings and select by pressing the right soft key.
Scroll to Audio and select by pressing the right soft key.
The phone will display the current ringing profile or style.
Highlight the detail option and select Change by pressing the right soft key.
Highlight "Calls" and select Change by pressing the right soft key.
Scroll through all options and select the desired Ringtone or vibration setting.
Press the end call key to exit.
Deleting a Ringtone:
Press the Menu key.
Scroll to "My MEdia"press Select.
Scroll to "Sounds" press Select.
Highlight the Ringtone to be deleted.
Press the Menu key.
Scroll to and select Mark.
Press the Menu Key.
Scroll to Delete Marked Files press Select.
A pop up message appears "Delete from phone?"
Select Yes.
Nov 07, 2009 | Cell Phones
Soft/hard reset combination keys doesnt work for nokia 6280
try this for soft reset
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Mar 06, 2009 | Nokia 6280 Cellular Phone
Frozen
Dont worry dr duncan, just do the soft reset by pressing the menu button and the centre button for 5sec. I amsure this will solve your problem. If it doesnt then u should upgrade ur ipod by connecting it to itunes through net. Please rate me...!!!
Thankyou
Feb 11, 2008 | Apple iPod nano
Buttons and scroll dont work
up up down and hold on orange button same time
Jan 20, 2008 | Activision Guitar Hero II for Xbox 360...
Button stuck?
or course, powercycle....if that doesnt work, a master reset will be needed.....because it sounds like there might be somehitng stuck on the screen in the corner for make it scroll around, clean the screen with a qtip and rubbing alchohol.....if that doesnt work, try a software reset. with the phone off, you will have to press and hold the button withthe lines on them and press the power button.....release the powerbutton.....the phoen should turn on and go to a black screen with white writing....release the soft keys here and press the green call button...it will reset the phone, but in turn, you will loose your info that is not stored on the sim or media card...
this is hard to do, so if you can navigate through the phone go to start, setttings, system, clear storage. it does the same thing. good luck :)
Dec 31, 2007 | T-Mobile Wing™ Smartphone
TYTN2 buttons not reponding - screen navigation fine
If a soft reset does not fix it,
Try a full hard reset:
Soft reset: Use the stylus to lightly press and hold the RESET button on the bottom of your device.
Hard reset: Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
Another Option if one of the SOFT KEY's is bad: START/SETTINGS/SYSTEM (tab)/CLEAR STORAGE.
Dec 05, 2007 | HTC TyTN Smartphone
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
