How to type japanese in windows vista
Now i'm using window vista. I don't know how to type japanese in window vista. Would you mind guide me how to type janpanese in window vista.
Thank you so much!
  • 449 Answers
Heelo, you will need to install a japanese language software on your computer system before you can be able to type in japanese
Posted on Dec 20, 2008
My laptop change to japanese language
Assuming you're using windows 7 or vista, go to windows start menu, and type in 'region and language' in the search box. There, you can check the 'format' tab if it was set to Japanese, or other settings like the "additional settings" or "keyboard and languages"
Hope that helps!
Sep 16, 2013 | Google Computers & Internet
Tip
Top 10 things to remember before installing WIN7
In this guide I will point out some important things that you need to do and remember before installing Windows 7 on your machine.
1 : Check the hardware requirement :- This is one of the most important factors that you need to keep in mind before thinking about Windows 7.Though Windows 7 should run fine with the 512 MB RAM system, it’s always better to follow Microsoft recommendations. Below are the Windows 7 requirements:
• A blank DVD
• A PC with a DVD burner
• A test PC for the Windows 7 Beta that meets these minimum hardware.
Recommendations (specific to the Beta and subject to change in the final version of Windows 7). Please do not use a PC you rely on for your work or daily use
• 1 GHz 32-bit or 64-bit processor
• 1 GB of system memory
• 16 GB of available disk space
• Support for DirectX 9 graphics with 128 MB memory (in order to enable Aero theme)
• DVD-R/W Drive
• Internet access (to download the Beta and get updates)
2 : Backup Vista :- If you are planning to upgrade from Vista SP1(SP1 is must) then it’s a good idea to backup your Vista drive so that you can revert back to Vista easily. I hope most of you know how to do back up task!
3 : You need to backup all your profiles and other important files that I have listed below. In case you are planning to wipe out Vista and install Windows 7 then also it’s better to create a backup of all profiles. Below are the important profiles that I backup:
• Documents
• Outlook pst file
• Windows live writer folder
• Saved games
• Other program profiles that you use.
4 : The most important thing for a web addict is browser bookmark folder. Use backup Bookmarks option in your browser to create a bookmark. Download Password Exporter add-on for Firefox to backup all your saved passwords. Also don’t forgot jot down all installed add-ons!
You can even use Mozilla Restorator to backup full Firefox profile.
5: If you have installed too many programs then it’s a good idea to generate list of installed application using a simple command that I have explained in the Generate list of installed applications guide.
6: Next obvious task is to backup all the custom settings that you have done to your Vista. Of course, you can back up! Type Windows Easy Transfer in Start Menu search box and hit enter to open. Follow the simple instructions to complete the task.
Windows Easy Transfer helps you move your files, folders, and program settings from one computer to another—all in one process.
Using Windows Easy Transfer, you can choose to move:
• User accounts
• Documents
• Music
• Pictures
• E–mail
• Internet favorites
• Program settings
7 : Move your Download folder from the “C” drive to any other safe location so that you will not lose the downloaded files.
8 : Though Microsoft recommends 16GB drive to install Windows 7 I recommend at least 30GB so that you won’t run out of free space in near feature.
9 : If you have any files in Desktop just move to safe place since most of us keep important files on Desktop for quick access.
10 : Last but least, don’t forget to retrieve Office and other product keys.
on May 11, 2010 | Computers & Internet
Tip
INSTALL WINDOWS 7 USING USB PEN DRIVE !!!!!!!!
Requirements:
*USB Flash Drive (Minimum 4GB)
*Windows 7 or Vista installation files.
Follow the below steps to create bootable Windows 7/Vista USB drive using which you can install Windows 7/Vista easily.
1. Plug-in your USB flash drive to USB port and move all the contents from USB drive to a safe location on your system.
2. Open Command Prompt with admin rights. Use any of the below methods to open Command Prompt with admin rights.
*Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
Or
*Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator.
3. You need to know about the USB drive a little bit. Type in the following commands in the command prompt:
First type DISKPART and hit enter
Next type LIST DISK command and note down the Disk number (ex: Disk 1) of your USB flash drive. In the below screenshot my Flash Drive Disk no is Disk 1.
4. Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don’t close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
6. Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
7. Type another command given below to update the USB drive with BOOTMGR compatible code.
BOOTSECT.EXE /NT60 H:
Where “H” is your USB drive letter. Once you enter the above command you will see the below message.
8. Copy your Windows 7/Vista DVD contents to the USB flash drive.
9. Your USB drive is ready to boot and install Windows 7/Vista. Only thing you need to change the boot priority at the BIOS to USB from the HDD or CD ROM drive. I won’t explain it as it’s just the matter the changing the boot priority or enabling the USB boot option in the BIOS.
Note: If you are not able to boot after following this guide means you haven’t set the BIOS priority to USB. If you got any problem in following this guide feel free to ask questions by leaving comment.
on Apr 02, 2010 | Computers & Internet
My pc is very slow
You mau need to make a few corrections in your configuration. Follow the guide below to do so.
Oct 12, 2012 | Microsoft Windows Vista Home Premium for...
I forgot my password and i dont know how to reset my toshiba satellite l25
Don't worry about it , I know the easy way to recover windows password, you can use the software called Smartkey Windows Password Recovery which is easy and effective to operate, and you can download and seethe using method from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
It can support Windows 8, 7,Windows XP, XP+SP2, XP+SP3, 2000, 2003, 2008, NT, Windows XP Professional x64Edition (64-bit), Windows Server 2003 x64 Edition (64-bit) Operating Systems,Windows VISTA, Windows VISTA(64-bit).I hope it can work out for you.
May 09, 2012 | Toshiba Computers & Internet
How do i change my monitor from japanese to english
No need to translate: Changing the display language in ...
windows.microsoft.com/.../no-need-to-translate-chan...
Microsoft WindowsOpen Regional and Language Options by clicking the Start button , clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional andLanguage Options. Click the Keyboards and Languages tab. Select Japanese or another language from the drop-down list, and then click OK.
how to change japanese language display to english ...
www.tomshardware.com > Forum > Windows 8
Tom's Hardware Guide
Feb 17, 2014 - 2 posts - ‎1 author
my laptop asus k55v windows 8 64 bit Japanese language and plssss,, help me how tochange to english.
how to change language from japanese to english in ...
www.tomshardware.com > Forum > Windows XP
Nov 6, 2013 - 6 posts - ‎3 authors
u mean i cannot change the display language from japanese to english in my window xp professional japanese version, even though thru ...
How to change display language in Windows 8. - YouTube
? 3:02
https://www.youtube.com/watch?v=kWT579KhuTM
Jan 25, 2013 - Uploaded by WinTipsOrg
If the display language is Japanese - what do you do to changeit to English? ... Same problem that others ...
Mar 27, 2012 | Cars & Trucks
How can I type Japanese o keybord?
Hai ! This is possible : )
Type in Chinese, Japanese, and other character-based languages
To type text on your computer in character-based languages, such as Chinese and Japanese, follow these steps:
[Source: http://windows.microsoft.com/en-us/windows-vista/Type-in-Chinese-Japanese-and-other-character-based-languages]
  1. Add the language as an input language. If you want to use an input method editor (IME), make sure you select it when you add the input language. For more information, see Add an input language.
    You can edit documents in multiple languages by changing the language (the input language) in which you type. Input languages are included with Windows, but you need to add them to your list of languages before you can use them.
    1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
    2. Click the Keyboards and Languages tab, and then click Change keyboards.
    3. Under Installed services, click Add.
    4. Double-click the language you want to add, double-click the text services you want to add, select the text services options you want to add, and then click OK.
  1. Change your input language to the language you installed. For more information, see Change your input language.
The input language is a setting in Windows that controls the language you use to type information on your computer. Before you can change an input language, you need to add that language to Windows. For more information, see Add an input language.
To change the input language
Click the Input language button on the Language bar, and then click the input language you want to use.
93d5c617-b1ec-4138-a1ff-973e71de80fe.pngLanguage bar gl_ico.png Note
If you don't see the Language bar, right-click the taskbar, point to Toolbars, and then click Language bar.
  1. Change your keyboard layout to the desired layout. For more information, see Change your keyboard layout.
You can customize your keyboard for a specific language or format by changing the keyboard layout. The layout controls which characters appear on the screen when you press the keys on your keyboard. Some input languages have several keyboard layouts; others have only one. For example, you can change your keyboard layout from the English QWERTY format to the English Dvorak format. After you change the layout, the characters on your screen might not correspond to the characters on your keyboard keys.
Before you can change the keyboard layout, you must add the input language and keyboard layout that you want to use to Windows. For more information, see Add an input language.
Hide all expcol_imgs.png To change the keyboard layout
  1. On the Language bar, click the Input language button, and then select an input language.
  2. Click the Keyboard layout button, and then select a keyboard layout.
gl_ico.png Note
expcol_imgs.png To change the keyboard layout on the Welcome screen
On the Welcome screen, click the Keyboard layout button 0c181420-8a93-48b6-82b1-b2dc25fc01b5.png, and then select a keyboard layout.
TIP:
After you are done you can switch between Japanese and English very easily by manually pressing the on screen buttons or using keyboard commands like SHIFT+ALT to switch between Japanese (???) and the Alphabet.
May 04, 2011 | Compaq Keyboard
Want an owner's guide too many dead ends
www.windowsvistauserguide.com
or
  1. [PDF] Introducing Microsoft Windows Vista File Format: PDF/Adobe Acrobat
    Understanding Windows Vista User Accounts and Windows Security. Permissions . ...... Windows Vista has two primary types of local user accounts: ...
    download.microsoft.com/.../5/.../Introducing_Windows_Vista.pdf - Similar -
    by WR Stanek - 2006 - Cited by 1 - Related articles
  2. [PDF] Windows Vista File Format: PDF/Adobe Acrobat
    Windows Vista – Power users guide. Page 1 of 66. Written by Mike Halsey, ...... this guide, this comes as a warning to us all! User Account Control (UAC) ...
    www.inspirare.net/pdf/VistaPower.pdf - Similar -
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
Bought new Gateway tower with Vista and can't connect my X5150 all-in-one printer.Can you help?
Hello brzmi
You can find Lexmark's support listing for you X5150 AIO (all-in-one) HERE.
And for Windows Vista specifically HERE.
It appears, however, that the drivers for this device are "bare bones". They only support printing for this AIO when it is installed on a Windows Vista system. Scanning w/ this device on Windows Vista is not supported.
If you would like to use the printing capability, then download the Vista drivers and install them.
Is that the difficulty you are experiencing? That you cannot use the device as you had on your pervious computer?
If you need a setup guide, you can find it HERE.
Keep in mind that the manual will describe features, etc. that will not be available to you w/ the device installed on a computer running Windows Vista.
If you still have a computer at home that is networked to your new computer *AND* that computer is running Windows XP.... then you can install the AIO on the older computer and "share" the AIO for your new one to use as well.
If that is an option for you, let us know and we'll step you through that process. You will only get the true AIO capabilities for this device on a system running Windows XP.
Please, let me know if I have answered your question. If I have not, or if you have other questions, please, post back here and let me know.
Thank you
BJ @:)
Please, remember to rate the "Best Solution(s)" solution *AFTER* your question(s) have been answered or your problem resolved. Thank you!
Apr 16, 2008 | Office Equipment & Supplies
Computers & Internet Logo
231 people viewed this question
Alun Cox
David Payne
David Payne
