Question about Acer Aspire 5100 Notebook
Acer 5100 boot up problem
My Acer 5100 LT crashes and then will not boot past the Acer logo screen but instead beeps twice and then gives the option of F1 to continue or F2 to enter set up. When trying to get in to boot to the XP desktop by pressing control-alt-del it does the same thing. Adjusting settings in the set up also doesn't work so they're now at default.At first I replaced the hard drive since it said that it was bad but this did not solve the problem. Then I tried removing the battery which worked a couple of times but not permanently and then re-installed the hard drive which again seemed to solve the problem but not completely. If I move the LT it will crash. I've sent this off to a reputable repair shop with no lasting success. The shop said it was probably the motherboard but I wonder if something is loose and shorts out or at least partially disconnected and acts up when I move the computer or close it.
  • jkjorg Dec 22, 2008
    It may just be that a new MB would solve the problem but the cost is to high to justify it . I 'd probably be better off buying a new one but I'm going to pursue a fix rather than a replacement .
    President:
  • 1,179 Answers
Sounds like a short in the motherboard. I'd go with what the shop said and replace the motherboard.
Posted on Dec 21, 2008
I am unable to restore my computer on D file
As the computer starts, press <F8> on the keyboard until the Advanced Boot Options menu appears on the screen.
new_note.jpg Note: You must press <F8> before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Mar 12, 2014 | Dell Vostro A860 Notebook
Dont startup
1 Turn on the computer.
2 As the computer starts, press <F8> on the keyboard until the Advanced Boot Options menu appears on the screen.
Dec 14, 2013 | Dell Inspiron 1501 Notebook
Acer aspire ast690 beeps once on start up,then will not boot past logo screen
the beep is a mother board error code though not all beeps signify an error. unfortunately i cannot find the codes key for your laptop as i write this but i would ask you is the beep long or short? are there any written error codes which appear?
Jul 27, 2011 | Computers & Internet
Can't boot up Acer 1641 WLMi. Sometimes I get the Acer logo on screen, other times screen is completely dark. When the Acer logo does come on, I see F2 option listed on bottom of screen but it doesn't...
Hold the f2 key down and keep it down... It will bring you to the bios which will allow you to boot in safe-mode or by using rescue cd or partition in your hard drive. Your hard drive may have problems or has crashed.
Oct 03, 2017 | Acer Aspire 1641WLMi Notebook
Blue Screen with error
Sounds like it's time to reinstall Windows without formatting, recover your data, and then format and reinstall Windows.
Process for your specific laptop should be located in the user manual and recovery disks that came with the laptop.
Nov 25, 2009 | Acer Aspire 5100 Notebook
My 5100 won't go pass windows loading logo
Try to boot in safemode press f8 key on startup
When the Windows Advanced Options menu appears, use the ARROW keys to selectLast Known Good Configuration (your most recent settings that worked), and then press ENTER.
if this does not work you can try MSCONFIG (if boots)to try diagnose your problem
if worse comes to you can do factory reset at acer bios screen hold the ALT key and press F10 to start acer recovery
hope helps a little let me know if i can help further
Nov 06, 2009 | Acer Aspire 5100-5022 Notebook
Acer reinstall issue
Run the same procedure again and choose factory settings. It wd do so , unless the recovery partition got corrupted.
Mar 17, 2009 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 wont start up correctly
please email me for more info on problem, meanness628@aim.com
Jun 25, 2008 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5100 will not start right
It seems your hard drive has corupted.
This sucks, all you have to do is push ALT F10 and then go through the reseting menu, you will loose everything on there though except the original data.
Jun 24, 2008 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5100 will not log on
If you have a Finger Print scanner (on select models), it may have failed, if you do not have this device , you may have installed malware - try rebooting and after you see the Acer screen start tapping F8 to get to speacial boot menu - choose Safe Mode and see if you can log in. If still unable, you will have to perform a system recovery - Acer provides an alternate way to recover - when you start the computer you see the Acer logo screen - after this displays hold down the Alt Key by the spacebar and tap the F10 key at the top of the keyboard once or twice - this will start the Acer E-Recovery program - follow the on screen instructions.
Jan 30, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
