Question about Mitsubishi DiamondPoint V50LCD (Black) Monitor
My diamondpoint nmx 56 has two wide vertical grey lines.
The vertical lines are two inches wide and are perfectly straight so I know it's not dead pixels. One line you can sort of see the curser in and the other has little bits of static distortions in it (like a TV with bad reception). The rest of the screen looks fine. I think it's just a loose wire in the back. You can even see the lines if you just turn the moniter on without the computer. I've tried different connection cables.
Help!
  • 275 Answers
SOURCE: thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Posted on Jan 25, 2007
techman
  • 3130 Answers
SOURCE: Vertical Lines on my Mitsubishi WS-65819
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Posted on Jul 11, 2007
  • 179 Answers
SOURCE: Picture displays green screen with random vertical lines except for PIP
can you post a picture please
ken
Posted on Nov 11, 2008
herman2008
  • 7 Answers
SOURCE: Vertical lines on my 40 inch lcd mitsubishi hdtv 1080.
I assume your Misubishi is not close to anything electrical. However, it sounds like you have had an interference for some time. This will ineviteably cause the HDTV LCD to collapse. LCD's don't respond well close to heat. Is there a vent close? LCD's do well in a properly vented area but with all this said.......they will pick up interference from anything electrical. A few questions to ask ones self........are there any wireless devices or chargers close to the LCD? Might there be an oven, a/c unit or other wiring with 220 volts anywhere close to the LCD such as in the wall?
The Mitsubishi LT is a very reliable, multi component ready set that allows great viewing with surround sound. However, stop and think about this interference. It is not something in the unit. It is an interference. Look hard and when you've discovered it.....you won't believe how crystal clear this set will be.
Let me know what you find...Thanks for using Fixya and add any comments that may help us help you.
Posted on Jan 16, 2009
benwabnick
  • 2404 Answers
SOURCE: Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Posted on Jun 03, 2009
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Vertical grey line about 2 inches wide appearing to the right of the page. Print seems ok apart from this. Tried new cartridge but still happening.
Teflon sleeve might be damaged, My suggestion replace both Teflon sleeve & pressure roller if available or else replace fuser assm..
Sep 27, 2011 | HP LaserJet 6L Printer
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
Computers & Internet Logo
52 people viewed this question
Top Mitsubishi Computers & Internet Experts
Alun Cox
Argospete
Argospete
john h
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
