Question about Nexland Internet Security Box Pro800 (200030) Router
Nexland Pro800 router stopped working after power failure
After power was restored, our three PC's were unable to connect. I did the following. 1-I tried connecting to the router via browser (192.168.0.1) which was alwas the default IP address, I could not connect. 2-I did ipconfig on my PC and strange enough my address was 169.254.104.36 3-I did ipconfig on the second PC and it's ip was 169.254.141.238 4-I didn't bother going further, because it's obvious that the router is dishing out ip addresses that are strange. How do I RESET the router?
  • Bill Valedis Apr 03, 2007
    First, THANK YOU for responding to my problem.
    1-There is a reset button at the back of the router, I tried it many times and it only restarts the router with no effect on IP address allocation. Every time I try it, the port IP allocations remain the same.
    2-There are 4 DIP switches at the back also, and I have no data as to what these do and these are currently all set to OFF (up). *** There maybe a combination of switches that must be set during power up, that resets everything back to defaults so at least I can get in the router.
    Does anyone know the switch settings needed to reset the Nexland Pro800 ???
    President:
  • 2,961 Answers
There may be a reset hole located on underside or rear of unit, but the ip address numbers that you mention are more than likely the ones set by windows, as is; what happens when you ask Windows to repair the connection, the DNS settngs may be incorrect also and is why you cannot get into the router. Your router may have reset itself and is not enabled to allocate automatic ip addresses so check that the DHCP is enabled.
Posted on Apr 03, 2007
Tablet connected to Wifi but does access websites
It looks like the wireless part of your wireless router is damaged.
If your friend's wireless computer/laptop cannot detect a wireless signal from your wireless router then this confirms the wireless fault.
Dec 04, 2012 | Computers & Internet
We have had a working router for 2 yrs, until my son pressed the middle button of the router. Now none of our laptops 'recognize' and are unable to connect. Our cell phones that used to connect to WiFI...
I just try to reset the router to factory default settings.Here is how:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Resetting the Router Using the Web-Based Setup Page
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Nov 15, 2010 | Linksys Wireless-G Broadband Router
Orange flashing light on the internet symbol and the internet will not work
Hi your router is not configured the properly
jus follow the below steps wil fix your problem
open the internet explorer type in the url box 192.168.2.1 if doesn't works go to start->run ->type (http://192.168.2.1)
1. once you login to belkin router page
If your internet service provider is Cable then follow the below steps
* open the internet explorer type in the url box 192.168.2.1 if doesn't works go to start->run ->type (http://192.168.2.1)
* on the left bottow you will find restore factory defaults if asks password leave it blank
* select connection type on top left you wil find if asks password leave it blank now choose dynamic - click on next you will find host name box below that you will see change wan mac address click on it ->click clone -apply changes
* Now check internet status on top right corner if it says - Connected then you wil be able to go online
if still unable to go online then
* First disconnect router power cord,then modem power cord then back of modem you wil see a cable wire or co axial cable unscrew (if you have battery remove that too )it remove wait for three minutes and plug all back
If your conenction is DSL Connection
2. on the left bottow you will find restore factory defaults if asks password leave it blanknow check internet status - if says connected you wil be able to go online
3.if not choose connection type on top left you wil find if prompts password leave balnk next page you wil find host name below that just click apply changes
Sep 26, 2010 | Belkin F5D7234-4 Router
Wireless connection not working
If you have made no changes to your network configuration, try unplugging the power from your router and modem for a minute. Then restore power to your modem, wait for the lights to come on and stay steady (all but PC and activity), then restore power to your router. Once the router finishes "start up" and establishes a connection to your modem, you should be able to connect to it and it should be able to assign an IP address to your computer. If you are unable to see your router in the list of available network connections, then you will need to a) refresh the list of available networks or b) write back for help on how to check the router's configuration. Either way, let me know how you make out.
Jan 02, 2010 | Compaq Evo Notebook Keyboard N610C/N600c
Laptops lose connection
You need to configure MAC cloning for your router to use the MAC address of the desktop PC if the router supports this. If not, then you'll need to change routers or continue to put up with the inconvenience.
For some reason(power glitch or failure possibly), your router is re-starting or resetting and apparently by default presents the first MAC address it sees to the ISP. The ISP apparently has registered your desktop MAC and only recognizes it and this is why you need to clone it.
Jul 18, 2009 | Dell Computers & Internet
Router wont connect to internet
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://192.168.1.1 or http://192.168.0.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
From the above configuration, please check if you can now access the Internet.
Apr 26, 2009 | NetGear -DSL Web Safe Router/ RP614 -...
Eee PC 900 has problem with wireless connection
Hi terryandy,
I am using the Eee PC from Taiwan also. It is running good.
Based on your scenario, have you tried changing another new router?
Your description of having "out of range" is highly probable due to router hardware failure.
Try replacing the router and update us again.
Thank you.
Jan 06, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
My computer stops working whenever I connect anything to the usb.
try to use the system restore feature,click on start, accessories, system tools, then click on system restore. try to restore back to a date before the "breaker" incident. if this does not work I would back up all my files to an external hard drive/dvd's then I would re-install my operating system (XP or Vista or whatever you have) if that doesn't work you may have a short in one of your computer components inside the machine itself, (that may need to be replaced)
Nov 14, 2008 | Nexland Internet Security Box Pro800...
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
Support
Try these steps:
1. First of all connect your PC Directly with Modem & check if you're able to go online or not.
2. If No , then contact your ISP.
3. If yes ,Disconnect CAT5 cable coming out of Modem from PC & connect into WAN port (on rear panel you'll find it) of Linksys WRT300N Router , After that on rear panel you'll find small hole with a Reset button inside it. Use needle or pen to press it quiet hard for 1 minutes continuosly, This'll restore all default settings.
4. After that give static IP - 192.168.1.2 to your PC ,subnet mask 255.255.255.0 ,default gateway - 192.168.1.1 & connect your PC directly with a LAN port on the back side of Router.
5. After that type 192.168.1.1 in the address bar of your explorer & login window will come , type username = admin & leave password field blank, then you'll get Blue coloured Router configuration page, From this page you can configure your Router.
6.Now if your Internet connection is Cable then default setting will work for you, However for DSL connection ,on this page you'll find internet connection type - selectiondrop down box - select PPPoE into it for DSL connection.
7. After that restart your computer & you should be able to go online.
Jan 07, 2008 | Linksys WRT300N Wireless Router
Nexland Internet Security Box Pro800 (200030) Router Logo
246 people viewed this question
Top Nexland Computers & Internet Experts
Alun Cox
Are you a Nexland Computer and Internet Expert? Answer questions, earn points and help others
