Question about GE JBP80 Electric Kitchen Range
Oven not working
On my GE electric stove the top burners work, the display is blank and the oven does not work?? model jbp80
  • GE Master
  • 19,396 Answers
This is either a faulty display panel, or a short inside the oven that is causing the panel malfunctioning.
The wirings, elements (both), thermostat contacts inside the oven must be checked for an eventual short. If there is none, replace the control assembly.
You find parts and diagrams here, just enter the correct model number.
Posted on Dec 20, 2008
Oven shuts off in middle of cooking/baking. stove top burners work just fine.
GE oven - SHUTS OFF ON IT'S OWN
I have a built-in GE Electric oven - model #JTP20B0F7BB. It shuts off in the middle of cooking sometimes, but not all of the time. It does it about 1 out of 4 times that I use the oven. Any help would be appreciated?
Apr 17, 2011 | Jenn-Air Ovens
Top burners stopped working but the oven does work
you can't do that by yourself if you are not technician.
check fuse and command board
Jun 10, 2010 | GE JBP80 Electric Kitchen Range
None of the top stove or oven elements work. Control lights come on but nothing is heating up at all. (GE JBP80)
The control is operated by 120 volts and the heating elements work off of 240 volts.
The most logical reason for your not heating (if there is none of the burners working) would be that one of the sides of the circuit is broken. Most likely this loss has occurred at the circuit breaker, try turning the breaker off completely and back on.
If this does not resolve the problem then the power loss may be a broken wire inside the range.
It is best if someone knowledgeable in electricity with a good meter does the testing beyond the breaker or fuse in the home.
May 07, 2010 | GE JBP80 Electric Kitchen Range
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Oven
Neal, the only thing I can bring up with that model number is a built in wall oven. You said the top burners work fine, so we are missing something here. Sounds to me like a stuck or shorted keypad. Catriver..post back
Sep 14, 2006 | GE JKP15 Electric Single Oven
GE JBP80 Electric Kitchen Range Logo
537 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
