Question about Compaq tc4400 Tablet PC (RL875AW#ABA)
Startup problem when i start the pc tablet, the it showed the regular hp logo, then it showed me another screen where i have to choose "start windows normally",:safemode, safe mode with networking, etc. when i chose normally, and as soon as windows xp was loading, there was a blue error screen for less than a sec and restarts my comp and takes me back to the choices again, can anybody solve this???!
  • Compaq Master
  • 13,433 Answers
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
Posted on Jun 03, 2009
Testimonial: "thank u for the info ,i needed some help on this, thanks again,"
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Nov 22, 2017 | Tablets & eReaders
Stream 8 tablet. Forgot password. How can I unlock?
Power Off your device, press Volume down button first, then press Power button for 3 - 5 seconds (do not let go of the volume down button). Startup menu will appear, select F11 System recovery on the mini Screen Keyboard. On the "Choose an option" menu, select Troubleshoot then Reset your PC (to be surely safe, plug in your AC when doing factory reset).
Note: All your personal files and settings will be wiped out.
Feb 18, 2016 | HP Tablets & eReaders
It is stuck on the logo android is there anyway to make the tablet work again
Second one in three days. Seems a know issue.
  • Android tablet stuck on Android Logo Fix - YouTube www.youtube.com/watch?v=B_bJeLnlClE
    • BY RICARDO GARDENER
    • 9 MIN
    • 237K VIEWS
    • ADDED 2014-08-13
    Video embedded · Learn how to fix your tablet that is stuck on the Android logo or ... Learn how to fix your tablet that is stuck on the Android logo or Android start ...
  • How to fix an Android phone if it is stuck or frozen on ... www.smartmobilephonesolutions.com/content/android-stuck-on-samsung ... or it boots up to its Samsung logo then freezes, ... How to fix an Android phone if it is stuck or frozen on the Samsung logo
  • Stuck Android Logo - YouTube www.youtube.com/watch?v=w6tmETIerBM
    • BY KELLER KING
    • 5 MIN
    • 553K VIEWS
    • ADDED 2013-06-13
    Video embedded · This video will show you how to restore your Ekko Tablet T700 if it gets stuck on Android Logo. Este v?deo vai mostrar-lhe como restaurar o Ekko Tablet ...
  • Android Tablet Stuck at Boot Screen - Stack Exchange android.stackexchange.com/.../android-tablet-stuck-at-boot-screen Android Tablet Stuck at Boot Screen. ... Samsung Galaxy tab 3 made in Korea stuck at android logo. ... T98G tablet stuck on boot screen.
  • Dec 29, 2015 | Tablets & eReaders
    How Do I Reset an Idolian Studio 10 Tablet that is looping on the Android logo?
    The robot dude meant it was loading up the system settings to the next screen so you can wipe off corrupted data that prevents the tablet from completing startup.usually an incomplete update.So
    as follows ... Hold power button to switch off tablet....then hold power button and volume up together for at least ten seconds.let the robot appear and do nothing until the menu option comes up to ask you to factory restore.you will lose all your apps and data.if the robot comes on and gets stuck make sure the tablet is fully charged and repeat the two button hold as this may take several attempts.sometimes Chinese technology is unpredictable.
    Jan 26, 2015 | Idolian 10.1" Android 4.1 Jelly Bean OS...
    Compaq tc4400 Tablet PC (RL875AW#ABA) Logo
    448 people viewed this question
    Top Compaq Tablets & eReaders Experts
    Jerry Umali
    Ann
    Level 1 Expert
    ray gallant
    Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
