Question about Hotpoint NBXR463EBWW Electric Dryer
Where would I find the thermo fuse?
I have a hotpoint electric dryer.
  • Barry Coates
    Barry Coates May 11, 2010
    Can you tell me the model number plz?
    Thanks
  • 3 Answers
It's usually by the blower.
Posted on Mar 20, 2009
  • 958 Answers
SOURCE: hotpoint tumble dryer condenser
have you clean the whole dryer air duct?. try cleaning all the walls for lints and check the blower wheel. it could be filty with lint and decreases the airflow there by increasing the temperature too much to blow those limit fuses. you would not believe how much dirt and lint we collect on those ducts. check also the exhaust hose at the back, it could hinder the flow of air if its dirty. and too many turns. as much as possible, limit the turns of the hose.
Posted on Feb 13, 2008
gotgeek2
  • 565 Answers
SOURCE: My whirlpool electric dryer runs but doesn't heat up
That' a very common symptom for a bad (open) heating element.
May or may not be DIY job to replace it. Would have to look at the manual.
Posted on Jan 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: Hotpoint Electric Dryer Model NBXR453EVOWW squealing when turned
Replace the drum support bearing at the rear of the drum.
Posted on Jun 11, 2009
marka19
  • 1430 Answers
SOURCE: I am looking for a diagram that shows the correct
Try this link http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5173996&diagram_id=1345233#d1345233
Posted on Oct 05, 2010
  • 3 Answers
SOURCE: kenmore dryer stock no. 69812 electric
Many times it is not a problem with the dryer itself. Just as in automotive and housing, when no one thing can be pinned down, look for the simplest and least expensive fix first. This would include a look at the wall plug and the power cable.. Ensure the power is off first, then unplug the unit from the wall. Check first the 220 power recepticle, then inspect the cable and all connections for signs of blackening or burnouts. Repair/replace all blackened or burned wires and cables as needed. Often times, even a dirty connection will not allow electricity to flow.
Posted on Dec 24, 2010
My Maytag MDE4000AYW electric dryer is not heating and drying my clothers
Check for a blocked vent. If the vent is blocked or restricted it will cause the thermo fuse to blow. If the thermo fuse is not blown check for a broken heating element. I hope this may help.
Jan 02, 2012 | Maytag Neptune MDE4000 Electric Dryer
My dryer whirlpool still blow cool air but do not heat please tell me what the problem henry le
Bad heating element or bad thermo fuse.
You will have to unplug the dryer and remove the back to access the heating element. The thermo fuse is located on the side of the heating element.
If you don't have a meter to test the element and thermo fuse or just don't know how simply remove them from the dryer and take them to your local appliance repair shop and they can test them for you.
Aug 03, 2011 | Whirlpool LER4600 Electric Dryer
Does thermal fuse burn out only because of temp.?
Possibly or the thermo fuse just went bad normally if the thermo-fuse blows its a venting problem warm moist air back builds into the dryer which in turn blows the thermo-fuse to save the dryer from further damage and also keeps from starting a fire in your home a big saftey feature that has saved many homes.
Jan 04, 2011 | Maytag HYE3657A Electric Dryer
My dryer is running but not heating and the timer after an hour or so has not moved. What could it be?
i would guess heating coil/thermo fuse but here is a website that has all the information you might need, Hope it helps Tim:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Oct 19, 2010 | Hotpoint Dryers
Dryer runs but dont get hot
CHECK THERMO FUSE OR ELEMENT AND MAKE SURE BREAKER DIDNT TROW 1 SIDE
Nov 06, 2009 | Hotpoint Dryers
Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Frigidaire electric washer dryer combo
i am asuming that when you say it works you mean it runs but not with heat? the thermo fuse is behind the back panel of the dryer the unit needs tobe pulled out to get to the back, you should see a bigger black thermostat next to a smaller thermo fuse, you can just jump the thermo fuse to see if that is your problem. it is not a fuse like you think of in your home.
May 22, 2008 | Dryers
Not heating up
I would check the thermo fuse in the back of dryer.. its on the burner towards the top.. use omh meter and check if its good. If you dont have a meter, if very careful and just hook wires togeter and tape so nothing touches and will not short out by touching anything, bypass switch JUST to see if switch is bad! Replace it if bad
Sep 05, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint NBXR463EBWW Electric Dryer Logo
65 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Starnley Johnwells
Starnley Johnwells
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
