Question about GE Profile PDW9880NSS Stainless Steel Dishwasher
Loose door handle on ge profile dishwasher
How I gain access to tighten the handle. both sides are loose.
  • 3 Answers
Take the inside panel off.  The 2 screws near the latch only need to be loosened.  Once the handle is off, you will find an allen bolt inside the shaft of the handle support.  Tighten and you are done.
Posted on Dec 31, 2008
GE dishwasher model GLD5868V15SS handle loose
This model comes with two types of doors. One with a single panel with integrated control on top or a two part door with control unit in front. The handle varies.
If you have a single door panel with handle bar across from right to left then you need to carefully unscrew the back panel screws and free up the front panel. the handle is screwed to the front panel from inside. Once you tighten carefully put the back door panel in and tighten. Take photos along the way to make sure you get back where you started. Also unplug dishwasher before working on it.
If you have a two part door with front control then handle and access to it is different. See diagram on this website for blow up of the panel and location of handle (part 713).
ESCUTCHEON DOOR ASSEMBLY Diagram Parts List for Model GLD5868V15SS GE...
You can magnify the image or take a full screen view for clarity.
Aug 29, 2014 | Dishwashers
Loose handle
Open the door and loosen the self threading screws around the sides of the inner door panel. Once this has been achieved lift the inner panel up so that you can access the door handle screws. Tighten these fasteners and reassemble the door panel.
Jan 24, 2014 | LG LDF6810ST Stainless Steel Built-in...
How do you tighten the handle on the microwave JKP78G0K2BG
You need to remove the screws that are holding the frame of the door to gain access to the rear of the handle assuming that the handle is not stripped out to start with.
Jan 30, 2013 | GE Microwave Ovens
The door on the freezer is loose
Using a putty knife, I pried the long plastic cover off the handle on the portion that was loose. That exposed the torx screw. When I attempted to tighten it, it turned without tightening, so I removed the screw. I pushed the thin metal trim piece away from the hole and squeezed crazy glue unto the hole. I let that dry. Then I was able to tighten the screw. I replaced the cover.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
GE Monogram ZBD0710 Dishwasher
THIS IS THE SOLUTION!
I was having the same problem with my Monogram dishwasher and oven.  Here's what to do.  You must fully remove the handle from the appliance.  Down the barrel of the standoff is a hex screw that, when tightened with an allen wrench, will draw the standoff tight to the handle again.  There is no need to remove the end caps.
Mar 27, 2008 | Dishwashers
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Dec 22, 2007 | Refrigerators
GE Profile PDW9880NSS Stainless Steel Dishwasher Logo
583 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
