Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Lots of mold and mildew stains on front door seal.
Bosch Nexxt 100 series front loader washer ( Model # WFMC1001UC) washer I need a cleaner to remove the mold and mildew stains or the directions to replace the front door seal. Any special tooling required and a parts lists.
Thanks
  • 1 more comment
  • Anonymous Jan 08, 2009
    Mold and mildew stains on front door seal.
  • Anonymous Mar 19, 2014
    where is the fuse located
  • Anonymous Mar 25, 2014
    cicle incomplete
  • 130 Answers
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
Posted on Jan 24, 2009
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch WFMC1001UC
Posted on Jul 22, 2013
Manual release on door lock of a bosch nexxt series 100 washer
Try pulling door up before out. My washer does this when the rubber around the door gets a piece of wet paper under it, or I have overloaded it and the rubber gets moved. Once open, run your fingers around the rubber seal to verify nothing under it and that it lays smooth.
Jan 03, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do i drain the water from my bosch nexxt front loading washing machine to remove the pump filter
I believe if you can get to it, put the hose end lower than your tub and it should drain. My front loader quit pumping and it was two quarters stuck in the pump.
Jan 02, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do I eliminate mildew from Bosch front loader washing machine? I've tried all standard remedies. I leave the door ajar after each wash load.
There is a product specifically for this issue, called washing machine cleaner. It is different from laundry detergent. You need to run the cleaner through monthly, and your issue should resolve.
Newer machines allow client to drain the water, attempting to address this issue, but I think the cleaner is required, or you do not get the mildew smell resolved.
Doc
Aug 04, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch nexxt series 100 washer. washer willnot start three beeps and all the lights are on.
Welcome to FixYa.
It sounds like a bad door latch/lock. It will require you to remove the front door seal spring to gain access to the part.
If this sounds like something you can repair I'll try and help in whatever manner I can or you may opt to call a pro.
Let me know how it goes and if you require further assistance. Thanks for choosing FixYa. Good luck
Regards,
Macmarkus :)
Feb 23, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Door gasket has mildewed and need to remove it for cleaning.
This video will show you how to change a door seal on this Bosch front loader washing machine
May 14, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Mold and mildew all around the seal.
The only solution here is for you to replace the door seal, and in future, do more high temp washes, as the prob is caused by doing too many low temp washes, ie: 40--50 degree temp washes, this causes build up of bacteria and the like.
Please rate my solution.
Thanks.
Oct 18, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
The door seal is torn at the bottom and leaks water on the floor
take the top off look down where the seal meets on the drum there should be a metal band the goes all the way round the rubber seal .you should see a long screw and bolt holding the band together unscrew the bolt and pull the seal off . the same on the front of the washer good luck
shaun
Mar 27, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
956 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
