I have a Gateway 500GR motherboard E210882 / D915GAG. What is the correct connector arrangement for what I assume to be connector S ? It handles the 3 connections from the front cover panel. HHD LED, PWR LED and PWR SW. Each one being a 2 pin connector that connects to a 2 row 10 pin connector on the motherboard with what I assume to be pin 10 missing. Pin 2 being on the sane row at the other end of the connector. There is an arrow pointing to the pin right above what I assume to be pin 2. I think the arrow means start counting pins here which would make that pin number 1. That would make pin 1 far right top row and pin 2 far right bottom row and continue counting in that order down and up from right to left.
You are correct so far.
This is a perfect example of using deductive reasoning based on intelligent thought.
'Armed' with that I can see you will go far in life.
Gateway Support > Gateway 500GR Desktop PC > Main Support page,
http://support.gateway.com/s/PC/R/3724/3724nv.shtml
Click on Components in the list.
Scroll down. Under the bold black heading - Motherboards - click on
102007 - Intel (Augsburg) No CPU Motherboard R0
Click on Specifications.
Chipset: Intel 915G Chipset
http://www.ascendtech.us/gateway-augsburg-intel-915g-motherboard_i_mb4gwaugsburg.aspx
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
In the photo the Front Panel header is marked by the letter S.
Let's go to Intel Support, and download the Product Guide for an Intel D915GAV motherboard,
http://www.intel.com/support/motherboards/desktop/sb/CS-012048.htm
Click on the blue -
Intel Desktop Board D915GAV Product Guide - (English) PDF
Scroll your mouse cursor to the bottom/middle of the page, to bring the 'ghosted out' navigation guide into view.
Click on the Adobe PDF icon to the far right.
(When you hover your mouse cursor over it, "Show Adobe Reader toolbar" is briefly shown)
Different design motherboard in the layout of certain headers, and connectors, but same Ol' Front Panel header pinout, Intel uses for 10 pin Front Panel header's.
Whether it is an Intel O.E.M. motherboard, or one they made for a pre-built computer manufacturer.
Front Panel header for Gateway 500GR, is next to the bottom edge of the motherboard, and all the way towards the right.
5 pins across the Top row, 4 pins across the bottom row.
Pins on the Top row are numbered ODD.
Pins on the Bottom row are numbered EVEN.
TOP row; Starting on the RIGHT side going towards the Left;
Pins 1, 3, 5, 7, and 9.
BOTTOM row; Starting on the Right side going towards the Left;
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode)
Pin 1 is for the Positive ( + ) wire. If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. No Connection. Pin reserved for the factory.
(5 Volts DC)
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) Again, there is No pin 10.
Regards,
joecoolvette
SOURCE: ATX-SW Motherboard?
The manufacturer website should have what you need.
You also might need to know what chipset is on the board as well.
If it is the AMD board, go to www.amd.com
I hope this helps.
Good Luck.
SOURCE: a GeForce7050M-M (V2.0)computer motherboard front
You may have the pins reversed.
Good Luck.
SOURCE: Which pins from the front panel of 6WMM7 go where?
There should be printer words on the motherboard next to the header. Use a magnify glass to look in and see. I will look for a diagram for you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Never hold the mother board on the cpu socket / ICs. Use the printer connector / usb conn. in that wat your static charges would have been grounded
Venu gopal
