Question about Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES 15 'no read' problem
Similar problem to many others with this unit I think. No matter what type of DVD I insert I get the three bangs of the lens driver against the shaft, a small spin of the disc and the 'no read' error. I have opened up the drive unit and as per some suggestions on the forum tried the following
1. Sliding the lens unit to the end of its track towards the back of the unit 2. Cleaning the rubber grip on the spinning mechanism.
Neither of the above appears to work. The unit of out of warrenty by 6 months. Looks like it may be a more serious fault requiring a new part but if anyone has any further suggestions please let me know
  • 3 more comments
  • gejkelly Dec 20, 2008
    Also cleaned the lens but to no avail..
  • gejkelly Dec 21, 2008
    Thanks for the suggestion but I don't think it will be worth getting a new unit. Any other suggestions?
    Thanks to all for help so far. The consensus seems to be that if lens cleaning doesn't work, and it doesn't, the only other option is back to a repair center?
    Such a pity that panasonic is now making equipment that simply will not last more than 2-3 years. I've been buying panasonic for 20 years and most of the equipment I have is still running. Looks like this piece of **** will be my last purchase with them.
  • gejkelly Dec 24, 2008
    Solution here is a repair involving time and a replacement part and while it will probably work I will just buy a new unit. Thanks for the help.
  • 6,487 Answers
This is really a problem with the lens of the unit and it should be replace and the only way you can have the lens replace is to take it to a service center and let them replace it , that will be cheaper than getting a a new unit...
Posted on Dec 21, 2008
  • 2,427 Answers
Yeah!!! contact panasonic for a replacement lens.. You need to change the lens. Only a few screws holds it in place so you can do it your self. The replacement comes with instructions (well i got mine with them) after you change it you will need to align it by adjusting the alignment screws.
    President:
  • 2,110 Answers
IT SEEMS THST UR LENS NEEDS TO BE REPLACED..SO TAKE TO NEAREST SERVICE CENTER...
    Genius:
  • 2,035 Answers
IF the message exists even after the cleaning lens then its the optical unit problem you need to replace whole optical data reader in the unit ....
Good luck..
  • Panasonic Master
  • 19,396 Answers
More than leaning the rubber grip, you need to clean the lens itself, inside the lens pickup, using isopropyl alcohol and a q tip cotton tip. did you clean the lens in this way?
If it does not work, replace3 the lens pickup.
  • Ginko
    Ginko Dec 21, 2008
    Nop read means Lens problem, and this fault is serious enough.
    If it was a problem obn the board, you get protection mode, when you get no disk on allo media, it is dirty lens, or faulty lens pickup, or no contact to lens pickup.
    Try cleaning the lens with alcohol , if this does not work, replace the lens pickup.
No read on my 2008 panasonic dvd recorder DMR-EZ485V
Insert a lens cleaning disc into it and let it play. If this do not help you, the optical pickup unit to your playder is faulty, and should be replaced.
Apr 30, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
The dvd player part of this unit doesn't work. When you insert a dvd it makes a sound like a dull beep as the unit appears to try to read the dvd. Then "Read" comes up on the display then there is a...
Hi
Thanks for using FixYa. When a Panasonic is giving "no read" and there are loud "clunking" or "chugging" noises this usually indicates that the lens is dirty or has failed. Other problems may include a failing or failed Digital PCB or some problem with the ribbon cables from the DVD Drive to the Digital PCB (on 2006 models such as the DMR-EZ models there is some problem with the ribbon cables to the DVD Drive on-board controller board.
Please check this picture for ribbon cable connections--
Click on the picture to Zoom In.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Shows unformat when DVD+RW inserted
Disc need formating. While disc is in the unit press Function on the remote then arrow down to Other Function then OK button then select DVD Management then select Format disc.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
My panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Jun 25, 2009 | Panasonic DMRES15 DVD Recorder
Panasonic DMR-E55 DVD Recorder won't read most dvd-r brands
Hello jancinn,
This might be due to a dirty pickup or scan laser head, or the optics as a whole might be going bad (both are common problems). A qualified TV repair person should be able to determine if the scan laser or pickup head are bad by doing a laser power test. If the optical devices are dirty it is just a simple matter of cleaning them with a DVD cleaning disk, however if the optics are bad, then replacing them is actually cost inefficient, and you may want to think about getting a new DVD player/recorder.
I hope this helps,
Thank you,
Shuttle83
Jun 02, 2008 | Panasonic DMR-E55 DVD Recorder
Panasonic dvd recorder DMR-EZ25EB error code sd any suggestions please ?
how can i get a Firmware for the Panasonic DMR-ES-15?
thanks alot 4 youre help...
Apr 08, 2008 | Televison & Video
Panasonic DVD Recorder Model DMR-ES15
For the unit to be confirmed if its o.k or not You have to take disc which is not very knew and slight scratches ,offcourse which is playing in your other dvd player.Play it on dmr-es 10 see if it plays normally,if it does than its lens is o.k.Other thing you can try is insert blanck disc and try formatting it,if it does than it s o.k.Try R+,R- AND RW+,RW-.iF This disc can be formatted on dmr es10 than the unit you can decide to purchase
Dec 18, 2007 | Panasonic DMR-ES10 DVD Recorder
Recording a TV program on a Panasonic DVD Player/Recorder
DMR ES 10 does not record on R + disc . change to R - disc and try
Oct 03, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES15
Just unplug it and let it sit for half an hour. Then try playing the lens cleaner disc, the problem would be fixed....
Sep 10, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 DVD Recorder Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
