Question about Samsung RB1955 Bottom Freezer Refrigerator
Samsung RB 1955 sh has F5 code showing when I woke up. Unplugged and tried restart. Not running and code still in display. What does code mean and how can I get it started. Thanks
3 Suggested Answers
SOURCE: samsung rb1955sh
if you hold the two top buttons on the right and left side of the display for 4 to 5 seconds it will reset the control board and it should restart, if not check the door switch for a bad connection. I had the same problem and i cleaned the contacts on that switch and reset the controller and no problems since. (2 months and counting!)
Posted on Mar 28, 2009
  • 160 Answers
SOURCE: SAMSUNG RB 1955 MY REFRIGERATOR
Check the temp in the freezer it may be starting to go bad. If the temp is where it is set than you have an ice block. If the temp is not where it is suppose to be than chances are your start relay is going out. Iff you need further assistance please comment me back.
Posted on Jul 29, 2011
We have KEB Combivert F5 drive Matno. 15F5C1E-350A Version. drive is installed in machine and is not working right now.i want to run the drive in Manual mode to test it.
if the display says LS, it means you are missing the speed and direction command. Via the keypad, provide the direction and then the speed.
Mar 07, 2015 | Inverter KEB COMBIVERT F5
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Kenmore model 790.96113403 F5 error code
it means that your oven is showing a restart code
Jun 13, 2012 | Kenmore 99123 Electric Kitchen Range
Error code F3 E5 when using self clean cycle
Error Code F3 - E5 - Oven temperature sensor (RTD) shorted (lower oven, if double oven)
Replace Oven temperature sensor (RTD) or Thermal Fuse.
Hope this helps.
Oct 08, 2011 | KitchenAid Kitchen Ranges
SAMSUNG RB 1955 MY REFRIGERATOR IS NOT WORKING NTHE FRIGDE IS ALSO BEEPING N NOT COOLING WHAT CAN I DO CAN U PLEASE HELP ME N TELL ME WHATS WRONG WITH THIS REFRIGIRATOR THANK U AND THE FREEZER WORKS FINE...
Jul 29, 2011 | Samsung RB1955 Bottom Freezer Refrigerator
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
Samsung rb1955sh
Dec 20, 2008 | Samsung RB1955VQ Bottom Freezer...
Whirlpool Electric range model RF386
cant nfind euf5 code can find eo f5 its a door loc code saing the door and latch switches do not agree try pushing stop/cancel and try again also does the oven light go off and on when you open and close the door
Dec 31, 2007 | Whirlpool RF364 Electric Kitchen Range
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Samsung RB1955 Bottom Freezer Refrigerator Logo
52 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
