Question about Lexmark X2350 All-In-One InkJet Printer
Power button flashing on and off
I have a problem with my Lexmark X2350. For some reason the power button is flashing on and off. Nothing happens when I press the button. I have tried disconnecting the power, but as soon as I power up again, the button starts flashing.
  • Anonymous Feb 25, 2009
    the power button of my printer cntinues to flash on and off.even when I try holding the power button nothing happens.I even try to plug it out and back in again still with no results.
  • dynaste Feb 25, 2009
    I have the same problem and it is not working still.any other suggestions?
  • Lexmark Master
  • 4,338 Answers
Check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen.
Check and see if the encoder strip is in place:
Encoder strip rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let me know if the lights are still blinking.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 28, 2008
The power button is flashing and it does not respond
Check your printer cartridge heads if they are clean or replace them ;)
May 21, 2010 | Lexmark X2350 All-In-One InkJet Printer
X2350 All-In-One InkJet Printer: How do I change the ink cartridge in a Lexmark x23...
Here's the User's Guide for your reference. Just click on this link: http://www.lexmark.com/publications/pdfs/2007/2300/2300-en.pdf . Scroll to Maintaining the All-in-One, Page 52, for instructions on how to change/replace the cartridges on the Lexmark X2350. In some cases, even when the printer is on and the cover open, the carrier doesn't position to the center. Unplug the printer from the power source. With the cover open, hold the solid white tape in the middle inside the printer. Other end of it is connected to the carrier. Slowly drag the carrier to the center loading position. Load the cartridges. Close the covers. Plug printer back to the power source. Hope this helps.
May 07, 2010 | Lexmark X2350 All-In-One InkJet Printer
The power button is flashing. When flashing I can
The power button flashing could be the printer trying to tell you that there is a problem with one of the ink cartridges.
You can shut the printer down by simply unplugging it from the outlet, wait 20 seconds and then plug it back in.
Also are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Oct 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 All in one software will not install. Also, nothing happens when scan button is pushed. Also, no imaging studio installed.
Lack of info. Does the head move or jog when the machine is turned on.
If so can you remove the glass plate and with the power unpluged to the all in one can you move the head down the track? Plug it in and turn the unit on to see if it retracks
If so disconnect the power again and then reassemble the all in one! Now as you turn it back on press the scan buttons many times and the number pad to see if it will confuse it's boot sequence.
turn
Jul 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark series x2350 all in one scanner does not work.
You will need to uninstall and reinstall the printer driver again, since the driver installation seems to be incomplete. Please follow the steps given below:
To uninstall, please follow the steps given below:
1. Click on "Start" and "All Programs."
2. Go to the "Lexmark X2300 series."
3. Click on "Lexmark Uninstall."
4. Click on "Next."
5. Click on "Finish."
6. Click on "Restart Windows" and unplug the USB cable.
You may copy and paste the web address below to access the Lexmark X2350 Vista driver to install:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:487:0:0&emeaframe=&fileID=12233&searchLang=en&searchLang=en&os_group=Windows%20Vista
Please use the following steps to download the Lexmark X2350 Vista driver to your desktop:
1. Select "Window Vista" from the drop down list
2. Click on "Download Now."
3. On the "File Download" screen, choose "Save."
4. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
5. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
6. Once the files have completed downloading, double click on the icon with your file name.
7. On the "Win Zip Self-Extractor" screen click "OK." To unzip the downloaded file choose "Unzip."
8. A screen will then display the number of files unzipped successfully, click "OK."
9. Please follow the on screen instructions to complete installation of your Lexmark printer.
Note: Please plug the USB cable when prompted while installing the driver. The USB cable should still be removed from the system, and the on-screen prompts will remind you of this. Eventually, you will get to a screen asking you to plug in the USB cable. This screen also has an "OK" button. Do not hit this button yet. First, plug in the USB cable. The screen should automatically detect and install the Lexmark X2350 scanner and printer drivers.
May 28, 2009 | Lexmark X2350 All-In-One InkJet Printer
Is the scanner driver installed ?. You can check this by unplugging the USB cable from the back of the printer and connecting it again. If you get any Plug and Play prompts on the computer, install the driver by pointing it to the correct scan driver location.
May 27, 2009 | Lexmark X2350 All-In-One InkJet Printer
The one/off green light flashes when the printer is turned on
You take out the paper (as it registers there is a paper jam) and then push the one/off button and it cleared.
Mar 21, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark 2735 power button flashing
Unplug the Power Supply from the Printer..........
Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so
that it should become like a thin long strip........ Now Insert that Envelope on the left side
corner of the Printer and move it from right to left and left to right as fast as u can for
about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the
catridges and Turn on the Printer.........
Good Luck..........
Jan 28, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 Paper Feed Troubleshooting
Check to make sure there arent any stray paper fragments in teh paper path. Also try taking a pencil eraser to the paper pinch rollers GENTLY.
Mar 26, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
446 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
