Question about Dyson Flowcheck CRO1 Front Load Washer
Fault F15 Washer will not go past main wash. i have canceled the programe and it will rinse and spin. but will not compleat a wash. help
  • GBarker Aug 31, 2008
    When the machine starts, it makes a clicking noise, then fault f15 displays, and the machine is unable to carry on
The gearbox actuator is seized....calll dyson and they will fix iy......free!!!!!!!
Posted on Oct 10, 2007
Smash the **** up and get a real machine!
Posted on Jun 30, 2007
Hi I have a indesit iwdd7143s washer dryer and the problem is as follows the machine starts a program ok then when it starts to fill with water it flashes f15 then it’s still taking in water on all cycles...
Either the inlet valve is faulty or the pressure switch is not controlling the water level. If the machine is still filling with the power off, it will definitely be the fault. If its intermittent, it could be the pressure switch. There is a remote possibility that the electronic controller has failed.
Sep 30, 2018 | Indesit Washing Machines
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 27, 2012 | GE Spacemaker Washer and Dryer Electric...
We had the problem where the washer would not empty all of the water but now that problem has been fixed THANKS TO ALL YOUR HELP cleaning the pump worked great!!!!! now I have another problem the washer...
Thedoor switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 02, 2012 | Frigidaire Affinity ATF6000F Front Load...
Maytag washer fills and washes but doesnt rinse or spin.
i would check your water level switch function, it will be located at the end of a 1/4 inch flexible tubing coming from the washer drum, my past experience indicates the replacement of this assembly will restore operation to your unit.`
Apr 16, 2012 | Maytag Washing Machines
Washer flashing spin light...can't cancel.... tried to reset by unplugging washer, tried starting a new cycle....nothing happens. Can't get door to unlock or washer to start.
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Seems that the controller is a suspect as it fails to move forward with the program/ Also check the function before we conclude.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Thank you for using fixya.
Aug 12, 2011 | Kenmore HE2 Plus Front Load Washer
Our LG Fuzzy Logic 8.5kg washer, model WF-T855A is not working in Wash or rinse mode - noise but no movement - Spin cycle OK. Have had periods in the past where water is not evacuated.
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 08, 2011 | Washing Machines
My washer won't wash and rinse, but it does the final spin
Possible that the water level sensor - pressure switch- is defective along with a possible fault in the inlet valve or the main program controller.
So you need to start checking from the program controller unit which on start with the door lid closed must activate the inlet valve and allow water to flow. If not this is a suspect.
Mar 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Last night I tempted to clean the large duet washer with the chlorine program. After starting, I realized I only had clorax bleach for colors and reluctantly used this. Large suds formed. I paused/cancel...
Drop your drain hose to floor level with bucket under it this will drain with no power applied , pour in as much water as you can to flush it out / clear pump .After all suds clear refit / restart ..Should now fill, wash/ empty and spin...I hope ...
Apr 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Drum doesn't really rotate on wash cycle.
No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
May 17, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Dyson Flowcheck CRO1 Front Load Washer Logo
501 people viewed this question
Top Dyson Washing Machines Experts
Sheldon Dedek
paul
paul
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
