Question about Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive
Only 100gb of my 200gb hardrive are showing
I recently got a maxtor sata drive and it shows up in my bios and when i format but it only is reading as a 131070mb harddrive or 131.07GB thats farly close to half my HD not useable is there a way to get access to that other part or does windows xp only read in 100gb chunks?
im runnig windows xp sp2
  • ZUES_1
    ZUES_1 May 11, 2010
    Hi
    Did you get this drive new? if so please post the data that s written on the HD, I use Maxtor drives and I have 4 500gb drives and they show up as 500 minus the idiotic way that windows measures THE SIZE as it keeps part of the drive for data from windows and the recycle bin along with the drives specs etc. If this was a new drive and you are sure it's 200GB it says the size of the drive in GB on the label that is on the hard drive. Also in the bios do you have any settings for SATA drives? As if you are not using it as a raid system you should set the bios to use the SATA drives as EIDE, IDE mode, if using UP TO 4 SATA drives set them to master and use SATA Drive 1 =Local drive 0 or C, with win xp etc. as with the size you mentioned sounds like it's a 140-150 GB, or your bios can't handle large drives, what type of MOBO do you have, how old and have you updated the bios to a more recent version. Also install sp3 to fix other problems found in sp2. If you have another PC [newer] and it can use sata drives also, put it in that pc delete all partitions and set it to use the whole disk as one partition, also try format c: /u the switch U tells the format software to format the whole drive unconditionally. After deleting the partitions put it the other pc and start it up if you have windows use the DISK DRIVE management and initialize the drive and then format it, if it still shows the same size it could be a 140gb drive. But before anything else just post me the spec sheet on the HD. So I know what the animal is.
    HTH
    Zues
Welcome to the wonderful world of windows disk size limitations.
What you are running into is the Windows 137GB Capacity Barrier AKA the 48-bit Logical Block Addressing Support for ATA (IDE), Serial ATA or ATAPI disc drives.
In English this means windows will only “acknowledge” between 127 and 137 Gig of a disk drive without some updates.
In most cases after he latest Service Packs are installed, any additional gigabytes will show up as unallocated space on the drive and you can create a second partition with the Windows disk management tools. Unfortunately this will mean that you have 2 partitions on the drive (if you placed your os on the drive or partitioned it before the updates were installed.).
If this is a secondary drive (in other words your OS is on a different disk drive), install all of the system updates first, you should then be able to format the entire drive as one partition.
Posted on Jan 08, 2009
11S09N0848ZJ1BLDP019YA
what problem, it is not shinny any more? LOL?
do say. please.
I am clueless, so far due to?
what system? PC, MAC,DVR,ext, TV, moon rocket.(LOL)
what OS?
using it as an internal drive, 2nd drive, or external.?
boot drive?
Seagate bought out MAXTOR.
that number must be a bar code, its not the product number
eg:
so tell me what it is.
as time passes, maxtor, fades to dark at SeaGate.
but this deep search nets, this, (hidden well)
http://www.seagate.com/gb/en/search/?keyword=maxtor
ive been using MAXTOR since day 1.
decodes for Maxtor :
Maxtor
xayb0
xa = drive family
- 6Y = DiamondMax(DM) Plus 9
- 6B = DM10
- 6L = DM10 RoHS compliant version
- 6H = DM11
- 7B = MaxLine(ML)III
- 7L = MLIII RoHS compliant
- 7H = ML Pro
- 4R = DM16
- 2F = Fireball 3
- 6E = DM Plus 8
- 5A = ML II
- 7Y = ML Plus II
y = the capacity of the disk, in gigabytes. Drives less than 100GB will have a leading zero (80GB is denoted as 080, etc)
b = buffer size and interface
- J = 2MB PATA with ball-bearing motor
- L = 2MB PATA with fluid dynamic bearing (FDB) motor
- P = 8MB PATA
- R = 16MB PATA
- M = 8MB SATA
- S = 16MB SATA
- F = 16MB SATA 3gbps
All Maxtor SKUs have a zero at the end. It may have a value, but I'm not aware of one.
Example: A Maxtor drive with a model number of 6Y200P0 is a 200GB 7200RPM PATA drive with an 8MB buffer from the DiamondMax Plus 9 family.
now my generic answer: for all HDD. A+ training....(instructor)
1: i make sure it has +5v and 12vdc power, if not all is hopeless.
2: IF PATA/SATA , i listen to the drive case with my ear.
whirrrrrrrrrrrrrr, no whirrrrrrr ,? its DOA.
if it spins its good. if not its 100% DEAD, (RIP)
3: do the gyro test, (if it fights you, as you change it's direction, then it is spinning) Drive in HAND. (whole deal)
4: does BIOS see it? (MOBO BIOS) hot key hit. RTM on MOBO.
yes, good.
no , DEAD. try another power cord to drive or data cable.
try different data ports. on MOBO.
5: try it on 1 PC, with step 4 and 5
6: if BIOS sees it ,so should WINDOWS. (may)
in the device manager.
and in disk manager. (off computer management CPL)
both. set the drive latter in the latter or it will be hidden.
keep in mind BIOS never tests a drive. it only asks it for
its NAME (PNP) PNP just identiifes the maker and type drive. and its spec. and 1 more tests. it shows the drive is NOT BUSY.
these facts ,help all techs, make good trouble shooting.
Sep 24, 2013 | Maxtor Hard Drive
Can't load xp on hp xw4300. Has sata hdd & ide dvd drive. Xp can't detect hard drive and if press f6 it says there is no floppy drive
replace your cables and try again. if unsuccessful locate your hardrives manufacturer ie: maxtor software MAXBLAST , download the hardrive software utility and ``0 fill`` your hardrive to factory default.
Nov 05, 2009 | Cars & Trucks
MAXTOR 250 gb usb hard disk is not detected
On some computers the output power of the USB ports is too low to drive the Ext. HDD.
Have you tried other USB ports on your computer?
Get yourself a powered USB hub and try that, borrow one if possible, if that works get one for yourself....
Aug 21, 2009 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
I have a dell optiplex, the primary HD is a Western Digital 160gb Sata I also have a LG DVD/RW combo drive set to master on the IDE channel. I recently attempted to add a 2nd ide maxtor HD and for the...
Hi there
When you into the bios settings choose default bios settings and save, reboot the machine and have a look in the bios again to see if the bios has picked the drive up
Good luck and kind regards
Jan 07, 2009 | Computers & Internet
Maxtor Personal Storage 3200 problems
change the driver letter. Duplication of drive letter will only show 1 of the drive.
May 15, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Hard disk problem
hmmm try to make SATA disabled from your BIOS setup. Because windows XP SP2 don't have any SATA driver, its came up with only IDE.
Try to disable your SATA it will fix your problem.
Thanks
Iqbal
Mar 23, 2008 | Toshiba Satellite A135-S2276 Notebook
Shrinked
This is the maxtor 4 installation utility: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=MaxBlast_4&vgnextoid=7add8b9c4a8ff010VgnVCM100000dd04090aRCRD Overview: MaxBlast 4 is a one-step, ATA/IDE hard drive installation utility. MaxBlast 4 makes hard drive installations and upgrades hassle-free for novices and professionals alike by automatically identifying, partitioning, and formatting any Maxtor ATA or SATA hard drive, making it data-ready in minutes. MaxBlast 4 replaces all previous versions of MaxBlast and MaxBlast Plus. Powermax 4.23: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=PowerMax_4.23&vgnextoid=a37d8b9c4a8ff010VgnVCM100000dd04090aRCRD Overview: The PowerMax utility is designed to perform diagnostic read/write verifications on Maxtor and Quantum hard drives. These tests will determine hard drive integrity. The PowerMax utility is effective on all ATA (IDE) hard drives with a capacity greater than or equal to 500 MB. Maxtor recommends the use of this utility for troubleshooting potential hard drive problems. These problems include, but are not limited to the following: * Potential hard drive surface problems (e.g., bad clusters, bad sectors, partitioning/formatting problems, etc.). * Drive recognition problems (e.g. hard drive that is not recognized by the operating system). * Software removal.
Mar 20, 2007 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive Logo
256 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
