Question about Canon PowerShot A95 Digital Camera
Error code E18
When turning camera on several beeps and screen goes back with error code E18
  • shohamlb Dec 25, 2008
    I urn on the camera and get E18 Error message
  • NOVOTNEY Jan 02, 2009
    I TOO just got that E18 error code yesterday Canon PowerShot A95!!! Camera has been great for the last 5 years and now that my warranty is up, the camera seems to be done. No where in the Owner's Manual could I find anything on this error code so also would like to be enlightened.
  • Canon Master
  • 4,738 Answers
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 03, 2009
My camera was dropped and now when i turn it on it beeps and then the screen goes black and says e18. i would like to take it apart since i have nothing to lose. do you have anything that shows how to do...
E18 error refers to a lens error .Try checking if any dust got on the lens barrel if not check with the Canon dealer for a replacement as this is might be a factory fault
Mar 31, 2011 | Canon PowerShot A400 Digital Camera
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
Camera does not power on. I get three beeps,
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 22, 2009 | Canon PowerShot S2 IS Digital Camera
Error message E18
Jan 12, 2009 | Canon PowerShot S1 IS Digital Camera
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2008 | Canon PowerShot A70 Digital Camera
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
A95 Trouble
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Dec 08, 2007 | Canon PowerShot A95 Digital Camera
Cannon power shot a70
Nov 24, 2007 | Canon PowerShot A70 Digital Camera
LENS STUCK IN EXTENDED POSTION
Nov 17, 2007 | Canon PowerShot A70 Digital Camera
E18
error code e18 means that the focus motor gears a jammed, dirt or grain of sand in them. you can try to fix it by gently banging the camera on somthing soft, their are also instructions on web on how to disasemble and fix this fault. BUT unless you have some skills, the right tools and conditions i would not attempt it. leave it to the experts
Sep 17, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot A95 Digital Camera Logo
409 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
