Hooking up a Kworld SA240 Wirless AV/PC to TV. Everything is working except the picture on the TV is continuously scrolling like the vertical hold is out. I"m thinking this has something to do with the refreash rate but not sure. I've tried the other refresh rates available on the pc in control panel but that's not helping.
  • daviddillow Dec 20, 2008
    Changing to NTSC helped with the vertical hold probklem but now that I can see the screen it is very out of focus. I have tried adjusting the sharpness control on the remote but that seems to have no affect. I am using my HDTV as my external monitor and running in clone mode. Is there something I can do to imrove the TV resolution so I can actually read what's written on the screen?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially and depending where you are, the color system has to match (PAL or NTSC). To my understanding the KWorld SA240 is set to PAL by firmware default and must be changed to NTSC. This could only be accomplished by the OSD (on screen display) settings through the remote.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 20, 2008
  • Louie  Role
    Louie Role Dec 20, 2008
    Appreciate the comment/postback.
    Understand that the vertical issue has been addressed. For your other concern, pls post back the brand and model of the TV,what is the screen resolution of the computer as well as its refresh rate.
    Cheers.
  • 19,396 Answers
Try switching the input channel on tv until you get the right input.
If the TV is connected using a cable, try a different cable, and test the connection.
  • 2 more comments
  • Ginko
    Ginko Dec 20, 2008
    Try first switching through input channels, to ensure you picked the right one.
    Then go to Control panel>>Display properties, and adjust resolution and display refresh rating. Initially put resolution: 640x480, and refresh rating same as TV value 60/75/85 Hz.
    Then increase resolution up to maximum supported.
  • Ginko
    Ginko Dec 20, 2008
  • Ginko
    Ginko Dec 20, 2008
    Additionally, if you are using a laptop, go to >> start-up >> open the execute/run command box and type>> “DXDiag” >>open “DirectX” >> Select FORBIDDING of DirectDraw accelerate option.
    Same opf your games may not work with this settings.
    “display”
  • Ginko
    Ginko Dec 20, 2008
    Hi there, follow the instructions here to improve display resolution, also try increasing computer res up to the maximum allowed.
    ftp://ftp.kworld.com.tw/kworld/faq/english/SA-240/SA240_FAQ_V1.00.20080430.pdf
    Copy and paste the link on your browser address bar.
    Thanks.
I drop my wireless internet connection in my house when I connect the computer KW-SA240 PCTOTV, I prbe in each of the 4 channels has and the same problem, I hope I can help
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
May 04, 2011 | KWorld SA240 Video Converter
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
Color bars only on KWorld PC to TV - Composite and SVideo
found this reference it may be of help
This product appears to be defective. I connected it to a working video camera that produces an excellent picture on a standard monitor. I looped the video from the camera through the monitor to the converter which is connected to a new ACER LCD display. The LCD display workes perfectly when connected to my computer. Using the converter, the results are poor. You can see the desired picture in the background but in the foreground there are horizontal bars that scroll vertically through the picture. I'm returning it for an exchange - will try again.
Jul 26, 2009 | KWorld PC to TV (0872880887527) Video...
No tv picture - only audio - after pc to tv box hook-up
Hi I am a silver surfer but this is how I got it working
First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables
Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
THIS IS FOR A DESKTOP COMPUTER
Jun 15, 2009 | KWorld PC to TV (0872880887527) Video...
Kworld pc to tv
You may have a bad tube or light if its a projection tv, try a different set of cables first and if you have the same problem, hook up the device to another TV, if it is still red the you know the device is bad, if not, the TV you are hooking it to may not be compatible
Mar 30, 2009 | KWorld KW-PCTV TV Input
Snes screen jumps, only on certain tv
Try the other channel.
If both are set to channel 4, change both to channel 3.
If both are set to channel 3, change both to channel 4.
Mar 16, 2009 | Nintendo Super NES Console
Everything works except picture
Most probable cause is the vertical output IC. You can get a replacenment at the following link.
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Can not get the picture to come up on cable
if you use the side buttons on the tv, and push the menu and volume down button at the same time it will let you into the interactive menu and continue to set up the tv to original set up. just follow the screens and your tv will be all good again.
Jan 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Dvb-t100 pci
This may be happening because VGA cable is too close to a power cable.
Oct 26, 2007 | KWorld DVB-S 100 (DVBS100) Video Capture
Computers & Internet Logo
19 people viewed this question
Alun Cox
David Payne
David Payne
