Question about Samsung RB1955VQ Bottom Freezer Refrigerator
Samsung rb1955sh I woke up and the frige is showing an F5 code and is not working..I unpluged for 10 min and same results when I plugged back in. Do you know what the F5 code means or how to restart the frige? Thanks!
If you hold the two top buttons on the right and left side of the display for 4 to 5 seconds it will reset the control board and it should restart, if not check the door switch for a bad connection. I had the same problem and i cleaned the contacts on that switch and reset the controller and no problems since. (2 months and counting!)
Posted on Mar 28, 2009
Dyson fan showing F6 error code
My machine displays an F4 F5 or F6 code
TROUBLESHOOTING •
Fault codes F4, F5, F6: If one of these appears on the display, unplug the machine, wait for 30 to 60 seconds and/or plug the machine into a different socket. If you continue to receive the fault code, please contact the
Dyson Helpline.
Fault codes F2, F3, F7: If one of these appears on the display, please contact the
Dyson Helpline
dyson fan showing F6 error code Google Search
Jul 31, 2018 | Heating & Cooling
We have a samsung front load dryer and it stopped working showing a flashing shirt
Try unplugging the Samsung dryer for 5 minutes.If plug is hard to get to,switch off breaker to dryer,then flip back on after 5 mins.Hope this solves your problem !!
May 08, 2017 | Samsung Dryers
No working
UNPLUG THE FRIGE FOR ABOUT 10 MINUTES AND PLUG IT BACK IN. IF THIS DOESN'T HELP YOU NEED SERVICE.
Jun 15, 2015 | Refrigerators
My samsung galaxy s4 wont turn on or charge
do not buy new battery...just connect to external power supply 4v 500 ma and after 10 min battery will be good
Feb 14, 2015 | Samsung GALAXY S4
We were baking when the power went out and later came back on. The normal "PF" came on but the oven light also came on and nowthe E1 F5 code was displayed. I was able to manually push the latch...
Unplug it for 10 min and plug back in. Go through normal setup procedures. I'm assuming it electric and may also have a reset. Hope this helps.
Jul 02, 2011 | Ovens
Oven door is locked after trying to clean and getting error code E1 F5
E1 F5 means your unit is having a problem with the door latch and lock assemble turn the power off for 10 min. and after turning the power back on wait another 10 min. before opening
Apr 05, 2010 | Whirlpool GMC305PD Electric Single Oven
My new (2 months) Samsung refrigerator barely dispenses water. It just trickles out. It would take 5 mins to fill a 20 oz glass. The ice works fine (good water flow to it). The water filter is fine....
The only thing between the inlet line and the spout?
Water Inlet solenoid, a valve that lets water in. Follow the inlet line to the back of frige. Unplug and turn off water before service. repace valve. EZ FIX...
Mar 29, 2010 | Samsung RS2534 Side by Side Refrigerator
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
What does F5 on a Kenmore limited Edition gas stove mean? the Mode# is 911.7398810 & the Serial# is 8C62220 Thanks
Your unit was manufactured by Roper. The F5 has two possible indications:
1. Bad door switch
2. Failed ERC (electronic range control)
Unplug your unit for a min. or more and plug back in, if the fault code (F5) returns, it is most likely the ERC and will need to be replaced.
Jan 29, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
Samsung RB1955VQ Bottom Freezer Refrigerator Logo
1,229 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
