Question about Frigidaire ATF6000ES Front Load Washer
Have to change bearing on front load washer
I have a fridgedair model fwtr445rfs1 front load washer. The bearing is gone in the back and it is throwing rusty water all over the inside. Im a millwright and work on machinery every day. Can someone give me the dissassembly steps to take care of this job. Please!
The bearing numbers are 6306-2rs and 6307-2rs which go with seal # G059 which I sell on Ebay.
Posted on Apr 22, 2009
    Novelist:
    Champion:
  • 220 Answers
This link should get you on your way. http://www.applianceblog.com/washers/RearBearingV6.pdf
In addition I should mention that the original bearings are a shielded bearing (Z). Follow the link and use 6306-2RS and 6307-2RS bearings which are sealed. I was able to match up SKF 562737 seal which is now a CR 15939 seal I believe. It is completely rubber coated. Between the sealed bearings and new seal you should be good to go.
Posted on Dec 29, 2008
I need a chart showing the error codes for a front load fridgedair washer model LTF2140ES3
Hi Richard....Google - Frigidaire front load washer error codes.
There are several links with code listings. Try the Sears Parts
Direct link.
Regards,
Dennis
Oct 10, 2014 | Cars & Trucks
Can bearings be replaced for fridgedaire washer model 970 c45062-00
If that is a front load the bearing comes as a part in the rear tub. it is moulded in the tub can't be replaced seperate//A top load the bearing is in the gearcase..If unit is more then 3 years old may be warranty on those parts check your book before you mess with it// might get parts for free just have to pay labour.If you need more help please ask me ....If I helped you please vote for me Good luck
Feb 05, 2011 | Washing Machines
Hotpoint first edition FEW 10P change dram or bearing,terrible noise
yep bearings are gone for sure so common with front loaders if can buy a top loader so much better value for money than paying for bearing jobs every few years.
Jan 05, 2011 | Hotpoint First Edition FEW10P Front Load...
Model # FWTR445RFS1. During the high speed spin it just started making a loud thumping noise. Tried sever different loads and it does not seem to be a clothes imbalance. I also took off the back cover...
There is a shaft that goes through a bearing in the back of the outer tub which supports and turns the inner tub. It is connected to the outside edges of the inner tub by a "spider arm". The normal play for the inner tub should be smooth, even and firm. If you can get it to move one way more than another one of the arms of the spider may be cracked. It would require removing ans splitting open the outer tub to inspect the rear support of the inner one.
Dec 19, 2010 | Frigidaire ATF6000ES Front Load Washer
Final spin loud noise out of balance??
sounds like your bearing is shot
is this a fridgedair?
does it sound like a 747 or freight train?
if yes might as well throw it away
I would say your looking at about 5-6 hundred dollars to repair
you will need the basket and outer tub
the reason is your bearing is compressed from the factory in your outer tub and your basket shaft goes through the bearing
and usually gets eaten up by the bearing
Feb 11, 2010 | Kenmore 43142 Front Load Washer
Drum came loose on Fridgedaire front loader on final spin cycle.
What was the point of posting this on the site?
The drum has broken loose from the support plate at the rear
You need a new drum and a support plate plus probably an outer shell.
A complaint to the manufacturer may get you a deal on a replacement
Jun 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Model 417.44072300 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer.
The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
Jul 28, 2008 | Kenmore 46462 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
779 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
