Question about Canon PowerShot A530 Digital Camera
Problem with Canon A530 Lens
My brand new canon A530 digital camera fell very gently on a very thick soft rug with the camera on in picture viewing mode. The Lens ever since has gotten stuck and does not go in or come out and the camera is now inoperational. Need help on making the camera to work again. thanks!
  • rtflone Jan 01, 2008
    Had exactly the same thing happen with my A530. Lens is now "stuck half way out" and camera is inoperable. Error message on LCD view screen says Lens Error please restart camera. Great! Restarting camera does no good...HELP!!!!
  • Anonymous Jan 10, 2008
    Same problem.. Any help???
    Scholar:
  • 130 Answers
I had this happen to a camera of mine a while ago, and I don't think there is a lot you can do except call Canon to see if they'll fix it or get a new camera, but before you do that, you could have a go at taking the whole camera apart and checking out how the lens works to try and see what's going on. Some gears are probably out of place. If you're lucky, you might be able to put them back.
Posted on Aug 17, 2007
Even when i put new batteries in my canon powershot a530 it continues to say change batteries and power off
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sep 15, 2010 | Canon PowerShot A530 Digital Camera
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 12, 2010 | Canon PowerShot A530 Digital Camera
When turned on, my Canon Power Shot A530 has a message that says N imagen, it does not prepare the lens for pictures, just stays with the black screen and the N imagen message.... do you have a solution?
try to change your SD card else There is an external software which you can install in your memory card and then you can insert it in your camera and if it does not work then go to canon service provide
Jan 14, 2010 | Canon PowerShot A530 Digital Camera
When Turning on the Canon Power Shot A530 the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
My canon A530 will not turn on
Damaged Lens Block.
Needs to be replaced.
Mar 20, 2009 | Canon PowerShot A530 Digital Camera
My lens is stuck half way out.
try Googling "E18" and read about this error signal and the many possible fixes. In your case sometimes gentle (really gentle) inward pressure on the lens tube while turning camera on (or off) will get it going again. Best wishes
Mar 04, 2009 | Canon PowerShot A530 Digital Camera
Lens error
The following blog outlines some simple repair options for a lens error. They won't work for all cases, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 09, 2007 | Canon PowerShot A530 Digital Camera
Unable to download pictures from canon A530 digital camera
Try removing the memory card and inserting it again.
Also, does the computer detect the camera properly?
Oct 18, 2007 | Canon PowerShot A530 Digital Camera
LCD LENS
Canon would appear to be correct with this diagnosis
Sep 21, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot A530 Digital Camera Logo
101 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
