Question about Microsoft Xbox 360 Console
I hve audio but no video with Xbox 360
I connect my Xbox 360 to a TV that is about 15 years old and I get sound but no picture. When I connect it to a newer TV, it works fine. Help!
  • trevor12332 Dec 20, 2008
    my X Box lost the picture and i still have audio helpppppppppp!!!!!!!
    Scholar:
  • 31 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio but no video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Posted on Feb 20, 2009
    Problem Solver:
  • 11 Answers
As of October 2008, a new motherboard configuration called "Jasper" which uses a 65 nm CPU & GPU is used in the newer manufactured Xbox 360 models. Because this new motherboard configuration is said to produce less heat, it might have a positive effect on the failure rate. The "Jasper" consoles require less power to run and use a 150 W power supply unlike the previous revision "Falcon" which used a 175 W power supply. It has been noted that these newer models have 256 MB built in flash memory instead of the 16 MB memory from previous models which many people believe is for the installation of the New Xbox Exprience, which requires 128 MB of free storage space to function correctly, the remaining space can also be used for the users to save games and other content onto it, rather than an external storage device such as the memory unit.
Posted on Dec 21, 2008
How can i connect my xbox360 to my t.v
well it depends if you hve an old tv or a new flat screen tv and your xbox should come with a cord that has three prongs (red, yellow, and white) and u go behind the tv and plug them into the tv in the colored spots that match the prongs.
Jun 08, 2012 | Microsoft Xbox 360 Console
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
http://support.xbox.com/en-us/pages/xbox-360/how-to/audio-video-devices/connect-xbox-360-console-tv.aspx
and for the video reset about halfway down the page:
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/xbox-360-top-issues/tv-or-monitor-screen-is-blank-while-connected.aspx
Mar 30, 2011 | Video Game Consoles & Games
Xbox 360 lights are green but it says mode not supported on the tv screen -no picture at all -even tried another tv and heard the audio at times but no picture-all cords intact-no ventalation problem...
Bad very bad.
It's bad solder connections under the G.P.U.
Trust me I know, I re-flow about 2-3 a day .
but the units are normally about 2 1/2 -3 years old
and 60% are Microsoft reworks. you can tell this by
a black dot on the safety seal .
You have 2 options Fix it you self , if done right you should
get 2-9 months sometimes more.
Or have a shop re-flow the G.P.U. . cost 80.00 or so.
you should get 3-12 month hard to say with these unit.
Rob
Nov 02, 2009 | Microsoft Xbox 360 Console
Cannot get picture just sound when i hook up my xbox elite system
Double check TV is on video 1,2,3 same for 360s yellow video out.
If then you still have audio only ,the G.P.U has open connections
form the video feed to the mother board
Solution, you must have the G.P.U re-clamp to the main board.
That Works. 99% of the time.
Jun 27, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360-no audio output
You may need to go into your TV settings and turn on HDMI Audio. If this is not enabled (Typically on HDMI 1) The TV will not ask the 360 for Audio and as such won't pull it.
Jun 20, 2009 | Microsoft Xbox 360 Console
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
My xbox 360 turns on with 4 green lights but i can not see any picture or sound
it sounds as if you have a connection unhooked or loose somewhere. Double check all audio and video cables are secure and in the correct position. If that doesn't work try troubleshooting by trying a different tv or removing all connections from tv and xbox and re-hooking everything back up.
Feb 19, 2009 | Microsoft Xbox 360 Console
No audio thru receiver with xbox360
Get some audio cables from radio shack or gamestop and use the regular audio jacks on the xbox to connect to your receiver.  Your video will be HD, but your audio won't.
Dec 22, 2008 | Denon AVR-1603 Receiver
XBOX 360
check connections.
e-mail me at B3652@live.com
May 31, 2008 | Microsoft Xbox 360 Console
XBOX 360
Your tv could have a losse connection on the video input. Try moving it around to see if you get any picture. Either that or u need a new audio video cord for your console
Feb 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
