Question about HP Pavilion dv6000z Notebook
Continous sound at Drive light
I am hearing a continous sound near the drive light. can u tell me the solution.
A continous beep sound is hear in my ups..........wat shall i do now
Continuous beeping can be an indication that the battery needs replacing, especially if you have had this UPS for awhile
Feb 22, 2013 | APC Back-UPS ES 350 - UPS ( external ) -...
Continous humming sound coming from hard drive, pls help
in future hard disk going to fail - take backup you data
Jun 08, 2012 | Computers & Internet
Toshiba L500 on boot up freezes and makes a continuous sound
This sounds like a bad hard drive, try a fresh install of the operational system to factory setting if disc is available, if no change remove hardware and reseat it back in place, still nothing the hard drive needs to be assessed.
Mar 19, 2012 | Toshiba Satellite L500 Series Notebook
GA-K8VM800M MOTHERBOARD The problem with the board is that, initially it got the message that disk boot failure, after checking bios settings, still it got same message. I have changed the IDE cables...
Try making your hard drive as the first boot in the bios and just connect your hard drive only on the motherboard ( remove cd/dvd drive, etc..). Make sure your hard drive is detected in the bios. Then restart your computer again.
Oct 11, 2010 | Gigabyte GA-K8VM800M Motherboard
Server making continual beeping noise......
Sounds like one of two errors - either one of the power supplies has died (not sure if the 1800 has redundant power supplies or not) or a drive in the RAID array has failed. Most likely it's the drive. Run the Dell Server Administrator tool to check the health status of the array, sounds like you need to replace a drive. Most RAID systems fail if you lose more than one drive, so I'd replace that drive ASAP.
Nov 09, 2009 | Dell PowerEdge 1800 Server
HP Pavalin ZE4200 goes into continous memory check on boot. I have two memory cards and have tried booting with only one card at a time in both memory slot to no avail.
Sounds like you may be lil confused. The chkdsk that keeps coming up on boot ,is telling you a hard drive has errors ,best reolaced.
Oct 08, 2009 | HP Pavilion dv9000z Notebook
Fails Post
It's the HDD, or the HDD controller. Give sony a call. Based on the number and sequence of beeps, they can tell you exactly what this issue is.
May 25, 2009 | Sony VAIO RC110G (VGC-RC110G) PC Desktop
SimpleTech Signature Mini (320GB) unable to find on my laptop
if you hear a constant clicking return the drive it is faulty.
Mar 27, 2009 | SimpleTech Signature Mini 320GB External...
Clicking sound coming from mother board
check your memory if the sound is continous beeping or your Video adapter. try to clean it and installed it again if problem occured use another memory or VGA for testing..
Jan 23, 2009 | Dell Dimension 2400 PC Desktop
Igniter
check your polarity at your outlet polatiry very important to theese re-ignition spark module, next with an old nail file)emory cloth clean the tops of the electrodes, after a whitle of continous sparking they tend to build up w/ carbon making it unable to detect flame thus continous spark
Feb 04, 2008 | Amana ARGS7650SS Gas Kitchen Range
HP Pavilion dv6000z Notebook Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
