Question about Coleman Cable Coldheat Cordless Soldering Tool
Replacement tips I have one of those little cordless coldheat soldering tools from Colleman. As it warns not to push hard on the tip, eventually someone at my house did. Where can I buy replacement tips?
    Scholar:
  • 75 Answers
I got one at Radio Shack. Where I live we only have a Dealer, not a large store but they have them.
Posted on Dec 22, 2008
Whats the little cup thing on top of the battery in a iso-tip soldering iron and is it glued on to that black thing with wires on or soldered ?
The cup thing allows thermal transfer to black thing which when gets hot trips switch adding resisters lowering charge current to trickle not to overcharge battery. Then red led lights, and is reset by pushing white slide towards bottom base. It is not glued it is pressure fit on bottom of black thermal switch and has a little thermal grease like heat sink compound. Should come apart if you pull hard enough maybe need to use pliers.
Mar 20, 2011 | Wahl Soldering Iron, Iso - Tip 60,...
Gun will not heat up tip unlesss it is pressed kind of hard against material? is this the way it is supposed to work...?
This sounds like a "contact" problem where the tip installs in the gun. I would remove the tip and burnish the connections with some very very light sand paper or steel wool (an emery board is a nice 'tool' to add to your tool box). You'll also need to clean the gun connections themselves. Also make sure the connectors are tight, but be careful not to overtighten them or you'll break them. Good connections = good heat transfer. Good Luck.
James
Jan 25, 2011 | Weller 8200 Soldering Gun
Weller PSI-100K doesn't ignite. I have taken off the tips and checked. There is a spark and I can ignite it minus the tip. It only then stays ignited if I keep pressure on the ignition switch. Once that is...
I have the same soldering iron and have found for this problem, the replaceable tip has worn out.
All you need to do is buy a replaceable tip of your choice. The tips are a consumable part that wears out.
Jan 09, 2011 | Weller Portasol Pro Cordless Butane...
My Weller pyropen does not ignite all of the time despite it having gas and a really good spark from the igniter. Is this a common problem and if so how do i resolve it It will also turn itself off if you...
Hi all, Just bought a WSTA6 iron, also wouldn't ignite reliably - just figured out you have to block the little air vent holes either side of the start switch with thumb & finger for 2-3 secs. while starting - 2-handed procedure :( -Now works like a charm :)
Couldn't find this info anywhere ???
Scotty
Oct 07, 2010 | Weller WPA2 Pyropen Professional Self...
Weller 8200 series soldering gun sometimes fails to heat; tightening screws and/or gently spreading arms often helps. Is there a permanent fix?
There is constant maintenance needed to keep soldering, the key ones are the tip fastening nuts, and the tip itself. The tip eventually needs sanding and immediate retinning, Clean with damp rag during and after each soldering event, and heavily re tin at end of event.
Sep 14, 2010 | Weller Welding Tools
How to take off a broken tip from impact drill dcf826
there are 4 hex screws the tip to fit it can be bought from most hard ware stores like drill dits they com in many different sizes. undo the screws and take of the tip toll be carefull to not not tip it downwards *** all the gears will fall out find the broken part take it out and replace with spare from dewalt supplys
best of luck sir
Aug 12, 2010 | Dewalt DW056 18 Volt Cordless Impact...
It is not melting the solder. do you have to use flux, like sweating copper? If so, can I use the same kind of flux for this application?
No flux, just make sure the element is heating up enough.
Also make sure the tip is clean. Let it heat up and dab on a wet sponge. You can also lightly file the tip to clean off oxide build up.
If you do this last step. It is critical you Re-tin the tip.
Of course the tip must get hot enough to melt the solder.
If it still does not, I would suspect the batteries.
Hope this helps!
Dec 19, 2009 | Weller BP860MP Dual Heat Battery Powered...
Tips are corroding & disappearing
That is normal for a soldering gun especially if you are using acid core solder. I do a lot of soldering with rosin core & have to change the tip about every 6-8 months. Just get a couple of new tips. Rick
Mar 06, 2009 | Black & Decker Black Decker Dualtemp...
No longer melts solder with tip....
You have burned out residue on the tip. Clead it off with a damp cloth when the iron is hot. If this doesn't get it all, use steel wool. Immediately afterwards, get flux & solder onto the tip or it will get coated again.
Jan 24, 2009 | Weller BP860MP Dual Heat Battery Powered...
Wacom Bamboo Fun Pen isnt working correct
I think you dropped the pen on its tip and broke the little ferrite sensing core.  You can try to repair it by gluing the core back together - it worked for me.  For detailed instructions on how to do it, go here: http://wishidknownthat.blogspot.com/2009/04/fixing-wacom-bamboo-pen.html  or you can try to swap the core for the eraser and the tip (more involved - you would need to be very good with a soldering iron to attempt this).  Either way - it's unfortunate that the pen is so fragile and that the user manual doesn't really warn you of this.
Jan 17, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Coleman Cable Coldheat Cordless Soldering Tool Logo
336 people viewed this question
Top Coleman Cable Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Coleman Cable Measuring Tool and Sensor Expert? Answer questions, earn points and help others
