Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite he3 dryer
THe dryer does not heat up in any modes?
where is the heating eliment
  • Anonymous Mar 07, 2009
    dryer running but no heat
  • 179 Answers
Take the bottom panel off the washer it is held in by two or three screws the heating element is off to the right
Posted on Dec 20, 2008
He3 gas dryer not heating
thee a lot compenents in the heat circuit it could be any one of them , starting with the thermal fuse,thermostat, safety valve ,glow bar, and flame sensor
Apr 30, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
http://homeguides.sfgate.com/troubleshoot-kenmore-elite-gas-dryer-wont-heat-77443.html
Apr 30, 2014 | Kenmore HE3 Gas Dryer
Kenmore elite he3 electric dryer no heat
Do you mean the heating coil was replaced? or the thermal cut offs?
You might have a bad thermostat or heating relay.
Mar 25, 2014 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE3 model 11094834200 it heats up for about 5 minutes and than stops heating. I replaced the thermistor thinking that was the problem but it wasn't. If I try re starting t
Number 34 is the sensor strips located on the rear bulkhead inside the dryer. Clean them thoroughly with Windex or 409. Dryer sheets build a wax buffer on them sensors that moisture cannot penetrate. If no wetness is detected the control shuts her down thinking them clothes is did. Either that or you forgot to reconnect the sensor wire when puttin her back together Kimosabe.
Jul 10, 2012 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he3 dryer has quit heating could it be the heating element and if so where can i find it on the dryer? The model # is 110.82822103 and the serial# is MR1751757
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Drum turns...no heat
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
Apr 19, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
501 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
