Question about Krups FBC112 1600 Watts Toaster Oven with Convection Cooking
How can I turn off the annoying "beep" on my Krups Toaster Oven?
If anyone in the house wants to get up early and toast a bagel, each push of a button on our Krups Toaster Oven (Ref. # FBC212/4G0) results in a loud beep --- and I mean loud!  Can this sound be disabled?  I can't find directions for this in the owner's manual.  All our other appliances give you the option of turning off the signal.  Help!  We're about to have family of all ages in our home for the holidays.  Some will want to sleep late and won't be able to!
  • Anonymous Jan 14, 2009
    Yes. Eager to hear if anyone knows a way to do this
Check out this link; might or might not help you:
http://applianceguru.com/forum1/15129.html
Please post whether this works for you.
Good luck, Sam
Posted on May 09, 2009
    New Friend:
I had the same issue with my Black and Decker toaster oven. I took the cover off and pulled the bell cover away from the clapper. The bell cover is still attached but not close enough to the clapper to make contact. Everything else works as it should with no noisy 'ding'.
Posted on Nov 20, 2015
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Waring TCO650 toaster oven - how to turn off or down the beeping
I found it! In the manual that came with the toaster (and not the one online), I found the following instructions:
1. To turn the indicator beep OFF: Press both [TOAST] and [BAGEL] keys and hold for 5 seconds.
2. to turn the indicator beep ON: Repeat the above process.
Note - if you lose power or unplug the unit, the beep comes back, so keep these instructions handy. :)
Dec 01, 2012 | Waring Tco650 Professional Toaster Oven
The toast button does not work properly anymore, guessing there is something wrong with the contact?
My toast button did that for a while then got better. Also, try holding the button in for a few seconds instead of a fast hit.
Jan 27, 2012 | Krups FBC2 1600 Watts Toaster Oven with...
Setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
Krups FBC5 unresponsive
Had the same problem. I ended up taking it apart and cleaning the knobs. Wasn't to hard to do. Remove a dozen or so screws. Unplug the control board and remove it. Wash and dry all of the knobs and re-assemble. Worked great since.
May 16, 2009 | Krups FBC5 1600 Watts Toaster Oven with...
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Toast button sticks and sometimes does not function. Sometimes it will work if it is jiggled.
I had the same problem which was getting worse. Eventually I took the oven apart by removing the feet, shell and front. Then I removed the circuit board on the front panel which has all the switches on it. We never use the "Defrost" function, so using a soldering iron, I swapped the "Toast" switch with the "Defrost" switch. The Toast function now works normally. I plan to get some spare switches for the next time one of these goes wrong. While I had one of them out I checked it out and a Panasonic P/N EVQ-PAE05R available from Digi-Key P/N P12192S-ND looks like it will do the trick.
Oct 20, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Krups fbc2 toaster oven cuts off while toasting
returned it to vendor and asked for exchange.  decided no way I should fix it after less than 5 days of use.  Curious if others have encountered a similar problem.
Sep 27, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Krups FBC112 1600 Watts Toaster Oven with Convection Cooking Logo
2,157 people viewed this question
Top Krups Toaster Ovens Experts
Stan Ford
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
