Question about Honeywell Programmable Thermostat Heater
I had an old thermostat that i had to change need wiring diagram
I had the thermostat (old) was the seco control ta2000 and am now tring to change to a honeywell non programable thermostat the code is rth3100c can you give a wiring diagram to help?
  • 24 Answers
Both thermostatats will have terminal designators R,W,Y,G, possibly O/B, C, W1,W2, Y1, Y2, etc.
Simplest method is to remove wires from old stat one at a time. mark where they came from and then install at same desinated terminal on the new t-stat. Hope this helps. be sure to shut off power supply to the unit (furnace) first. The wire coming to the R (RH,RC) terminal is the 24 volt a/c hot, all others are feeding back to perform given function.
Posted on Dec 23, 2008
    New Friend:
E and AUX need to have a jumper wire to connect the two. W2 (white) goes to the AUX terminal with the jumper installed. Y to Y, G to G, O to O, R to R, X (probably blue), goes to C, but is optional since the RTH3100C has batteries.
Posted on Jan 03, 2013
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
Replacing a TA2000 WITH RTH6500fw
the terminals where the wires go should be marked with letters put them back on the new t-stat matching the letters c is common on heatpump white and yellow should be jumpered togeather and if your new stat has rc and rh they should be jumpered and on heatpump there should be either an o or b hooked up but not both this is for shifting heat or cool
normaly red to red 24v hot...green is indoor fan....yellow is compressor and or white also....blue is reversing valve energize for heat orange is energize for cooling ...and black or brown is common which is neutral or ground for the 24volts
Mar 14, 2014 | Heating & Cooling
How do i wire analog thermostat to digital
You need to get a different thermostat.you can change an analog thermostat to digital, but you have to replace the motherboard with a digital compliant one. You can't just change the thermostat. Your best bet is to put back the old thermostat or upgrade to a different compatable thermostat
Jan 20, 2018 | Dometic Rooftop RV Air Conditioner
How to connect to my Air conditioner AZ28E15DABm1 GE a thermostat model TR400 HC-A SECO?
carefully follow the below steps;
Turn off the circuit breaker that controls the air conditioning system. Turn the thermostat to the "On" position to make sure that all power is cut off and the air conditioner cannot accidentally operate.
Remove the cover of the existing thermostat and remove the colored wires from the terminals. Take out any screws that secure the thermostat to the wall, and remove the thermostat.
Mount the new thermostat on the wall. Feed the wires through the unit, with enough slack to allow you to make the new connections.
Connect the red wire to the thermostat terminal labeled "RH," "RC" or "R." The red wire carries the power from the transformer.
Connect the green wire to the thermostat terminal labeled "G." This controls the relay that controls the fan. Attach the yellow wire to the "Y" terminal of the thermostat. This powers the main control. Connect the white wire to the "W" terminal. This is the heating control wire.
Close the thermostat's cover and turn the breakers back on. Turn the new thermostat to the "On" position to test it and that would be all.
I hope the above helps. If it is not helpful, please let me know so that I may direct you further.....
Good luck.
Feb 25, 2011 | GE Zoneline AZ38H12DAD Split System Air...
I want to change to a programmable thermostat my old one is 8846 and i need to have a wire diagram in order to change wire or its a lr1620 might be the model
  • Red to the thermostat RH or thermostat RC terminal with a jumper wire between thermostat RH and thermostat RC. Or Red to the thermostat R terminal which is shared with both the heating and cooling. It has an internal jumper built in to the sub-base. The red wire is the source hot wire from the transformer. All other wires, except the common wire, controls a specific relay or contactor that energizes the fan, heating, or cooling depending on the selection. The following is the common wiring colors but your system may not be common and different colors could have been used.
  • Green to the thermostat G terminal. This is the color that controls the fan or the relay that control of the blower.
  • Yellow to the thermostat Y terminal. This is for control of the air conditioning.
  • White to the thermostat W terminal. This is for control of the heating.
Here is the link you can copy and paste in your browser: They also have every other model here to:
http://highperformancehvac.com/thermostats_2.html#new_thermostat_installation
Jul 08, 2009 | Honeywell Electronic Programmable...
I am changing from a Seco control thermostat model # tb1540e-g to
Rc/Rh should be from the transformer if a single transformer system. If its'a dual transformer system, then there should be a red wire to each from it's respective unit (furnace=Rh, condensor=Rc.).
W should be heat.
Y Should be cooling.
G should be fan.
I am not certain what E is, unless the stat can be used on a heat pump with backup electric heat, in which case it's for the electric heat.
The reason I say should be, is because if you are looking at wire colors, and not terminal designations, there is no guarantee the control wiring was connected following normal convention.
Reply back of any further questions.
Feb 03, 2009 | Honeywell Programmable Thermostat Heater
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Dec 20, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
1,298 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
