Question about Refrigerators
My GE Refrigerator is barely cooling. Help!
What can I check to resolve this new problem?
    Problem Solver:
I am by no means a repairman. Just a housewife that had the same problem. Sometimes it can be that the coils need to be cleaned, I had that prob before and I used the vaccuum brush thingy and cleaned them and that did the trick. The next time it was my thermostat that went out, so my hubby took it out and saw if it worked, with out it, which it did, very well, almost to well. The milk had ice and the onions froze! We ordered a new thermostat and replaced it as soon as it came in and now my frig is working like a charm. Hope this helps some. Have a Blessed Day!
Posted on Dec 20, 2008
GE Profile - Both freezer side and refrigerator side too warm - set the the temperature controls to coldest, items in freezer no longer frozen and refrigerator side just barely cool.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | GE Profile Side-By-Side Refrigerator with...
Ge profile refrigerator/freezer, freezer on the bottom. Refrigerator stopped cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 06, 2010 | GE Refrigerators
Ge monogram refrigerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
erwfj,
May 31, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Ge side by side refrigerator not cooling
heatman101
9780hf
Apr 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
I have a GE side by side Fridg.that is approx 7-8yrs old.The freezer side is working fine but the fridg. side is not cooling. staying at about 50 degrees just barely cool.. This seemed to happened...
Setting the cooling setting up all the way will not help at all.Make sure your freezer and refrigerator controls are about the same setting. Temp. settings for refrigerator should be between 38-42.degree at medium.. Freezer about 0 to -10.If it is a simple fix this will help.
Feb 20, 2010 | GE GSS20IEP Side by Side Refrigerator
GE refrigerator is not cooling. Changed the
Your thermostat may be broken, I'd check that first.
Feb 04, 2010 | Refrigerators
GE Refrigerator/Freezer not cooling
Loss of coldness is common with compressor related problems....relay and overload(simple fix), loss/leak of refridgerant(need a cert. tech). need to check the compressor and see if its running....do this by pulling the unit out and removing the back panel, place your hand on the compressor and see if it feels like its running....if not probably just a relay, if it is running, could be a more serious problem dealing with sealed system.
Jun 10, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
GE GDS18LBP bottom Freezer - Refrigerator not cooling
heatman101
dl;
Feb 17, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
