RCA DRC286 DVD Player what size usb can be used
WHat size of a USB stick can be used and is it possible to use an external hard drive?
  • Anonymous Apr 06, 2009
    I put a 500GB hard drive on it... but it is slow to load up.
  • 135 Answers
SOURCE: wharfedale DVD1100 PLayer does not detect USB Hard drive
It's unlikely that you're doing something wrong. Did you buy this DVD player as one that is supposed to support connecting hard drives? If not, then the player probably doesn't support connecting a hard drive.
Posted on Jan 08, 2008
SOURCE: xbox 360 usb port
Ive never had a problem with my 160 GB portable hard drive
Posted on Jan 28, 2008
  • 106 Answers
SOURCE: help
maybe,but you must have a drivers for that disk installed on your dvd
Posted on Feb 07, 2008
Basti
  • 1447 Answers
SOURCE: to boot window xp from usb external hard drive
Use the guide in this link
http://www.ngine.de/index.jsp?pageid=4176
or this forum
http://forums.ngine.de/viewtopic.php?t=1764&sid=a81e27622dda029af42cb532e7cfcd28
pls dnt 4get to rate solution, thanks!!
Posted on Apr 15, 2008
SOURCE: USB external hard drive driver
If you go into Computer Management and go to Storage > Disk Management. You'll see the partition there. Right click on it and assign it a drive letter. You will be able to access it from there.
Posted on Jan 30, 2009
Hitachi 50hyt62u H can I add a removable drive as I have a slot in Back for one, and if so where do I get one
You should be able to buy an external USB drive (or thumb drive) at any electronics store.
You can connect a USB hard disk drive or USB
memory stick to your TV by using the USB inputs of
the TV. This feature allows you to play files stored in
a USB drive. 2.5" and 3.5" inch (hdd with external
power supply) external hard disk drives are supported.
IMPORTANT! You should back up your files before
making any connections to the TV set in order to
avoid any possible data loss. Manufacturer will not
be responsible for any file damage or data loss. It is
possible that certain types of USB devices (e.g. MP3
Players) or USB hard disk drives/memory sticks may
not be compatible with this TV.
Quickly plugging and unplugging USB devices, is a
very hazardous operation. Do not repeatedly quickly
plug and unplug the drive. This may cause physical
damage to the USB player and USB device itself. Do
not pull out USB module while playing a file.
Media Browser Menu
You can play photo, music, and movie files stored
on a USB disk by connecting it to your TV and using
the Media Browser screen. To do this, perform the
following: Connect a USB disk to one of the USB
inputs located on the side of the TV.
You can connect two USB devices to your TV. If both
USB devices include music, picture or video files, USB
selection OSD will be displayed on the screen. The
first USB device connected to the TV will be named
as USB Drive1. Select a device by using up or down arrows
and press OK
Nov 23, 2017 | Hitachi Computers & Internet
RCA 24" Class LED-LCD 1080p 60Hz HDTV 1.7" ultra-slim, LED24A45RQ USB input
One use for the USB inputs on flat screens is to allow you to connect a USB stick or external hard drive and watch or view any external files you have.
Hope that helps!
Aug 11, 2014 | RCA 24" Class LED-LCD 1080p 60Hz HDTV 1.7"...
I want to turn a memory stick into hard drive. How can i do that?
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
Oct 02, 2012 | Sony Vaio VGNBX196SP
Thompson DVD player USB reader
check usb format - keep fatt32 or" fatt format system.
May 28, 2012 | RCA Thompson DVD Recorder
My LG BD530 Blue Ray dvd player /usb will accept my 16GB flash drive to view movies as it has a usb plug in. It will not let me play the same movies from my Western Digital 750GB external hard drive. When...
Could very well be that the external hard drive is drawing more power than what the player can deliver - it is enough for a usb stick but not for the external drive. Now if you use an external drive that is self powered I am sure there will be no issue.
Mar 27, 2017 | Televison & Video
My buffalo external Hard disk is not working in the Philips DVD player. 4 gb pen drive of Sony is working. What is the problem..? how can I correct it........?
Some usb input ports on dvd players, projectors, etc. have a limit to what size it will read from. Right now it's usually 4 gb to 32 gb.
Apr 03, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
I am trying to view pictures and videos as well as music form my seagate 250gb expansion portable hard drive, through my dvd player via usb port. it reads "no data" is there anything that i can do to...
Most probably your harddrive is formatted using NTFS file system, while your DVD player only understands FAT32 filesystem.
Check the format of your drive by hooking it up to a computer and opening it's properties. And check your DVD player's specifications regarding USB support in it's manual or online, on manufacturer's website support section.
If indeed the filesystem type is the problem, you can do a couple of things:
1) Purchase a Flash pendrive of suitable capacity (these are FAT32 usually) and use it for viewing pictures & videos on your DVD player,
2) Move everything temporarily from your external hard disk to your computer's disk and re-format your external drive using FAT32 filesystem. Note, that FAT32 has some disadvantages, like a 2GB file size limit. And also remember, that formatting the drive wipes everything from it, so be sure to copy all stuff to your computer's internal drive first!
3) Check the possibility of connecting your PC to the TV directly and forget about the DVD player for viewing pictures and videos.
Dec 25, 2009 | Computers & Internet
I just bought an Aveis 1080p upconverting DVD player and when i put my USB device in it doesn't it says unsupported. What kind of USB device should I get
USB stick has to be formated in FAT32 file system.
Some players will only play sticks up to 2 Gigs, some may recognize and play video files even from external hard drives.
Aveis is a no name player, so who knows if it'll play anything besides MP3 and JPG.
I'd go with a Pioneer or Coby (both at Best Buy); both play DivX format from sticks and external hard drives; no MPEG-4 or MKV files though, which is a bummer (did not find any player under $100 that does.)
I tried them both (also tried Philips and Toshiba), but the Pioneer had far the best picture and sound amongst all of them. Coby was OK, but the display broke.
Oct 17, 2009 | Televison & Video
Wharfedale DVD1100 PLayer does not detect USB Hard drive
Jan 08, 2008 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
