Question about Jenn-Air JCD2389G Side by Side Refrigerator
Coil a frozen block of ice 1999 Jenn-Air JSD2374ARW
Consequently there is no air flow to the frig side. I thawed it out thoroughly and it worked great for a couple days now I have the same problem. What is the most likely culprit and how do I find a schematic for this frig?
  • dpannell574 Dec 20, 2008
    Is the freezer door gasket in bad shape?
    Problem Solver:
  • 6 Answers
The most likely cause of the problem is the defrost timer. It's job is to cycle the heaters for the coil on and off at intervals, possibly every six hours the heater should come on for seven to fifteen minutes. The timer is easy to replace and you may find a schematic online if you google jenn-air.
Posted on Dec 20, 2008
I have a Jenn-Air Refig with the freezer on the bottom. The ICE maker is not working and I think it might be frozen. How do I disconnect the ice maker so i can thaw it out?
Why not do a quick thaw and move the frozen goods over to the firdge for a few minutes and grab a blow dryer. This should give a temporary fix until you can pin point the problem. Be kind to me please with a Thumbs up. I am a long ways away and can only help a little. Raz
Apr 09, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Tip
Air Conditioner Ice Air Conditioner Problem
If you are experiencing the problems caused when your air conditioner becomes a solid block of ice then you need to figure out the real reason why it does or is doing that.
There are a few things that can happen to cause this unpleasant happening.
  1. The air flow over the coil is choked off to the point where the coil starts to become to cool because not enough air is flowing over it to keep it warm.
    1. Check air filter, if dirty clean it. (This is a very common problem)
    2. Check supply vents in building to make sure enough are opened to allow air flow.
    3. Check blower motor to see that it is operating at full speed.
    4. Return air temperature may be too cool. (below 65F)
    5. The indoor coil it’s self may be plugged with dirt. Clean with a good indoor coil cleaner.
  1. The outdoor air temperature maybe to cool which makes the indoor coil run too cold.
    1. Install a head pressure control to keep the high side pressures up.
  1. The unit may be low in refrigerant. This is often the first thing that gets the blame for causing this problem. Actually it should be the last thing to check after all the other possibilities are thoroughly checked.
If you have a coil that is froze up to a chunk of ice, then you need to remove power to the outdoor unit. Allow the indoor fan/blower to run to try to move air over the coil and thaw it out.
After the coil is completely thawed, then restore power and determine the cause of the freeze up.
A heat gun or hair dryer can assist in the deicing process. Towels and a wet/dry shop vac can help to keep the mess to a minimum also.
on Jan 03, 2010 | Heating & Cooling
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
My Jenn Air JCB2285HES not cool on both sides not frozen line
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
jljhfjg
Oct 21, 2009 | Jenn-Air JCB2285HES Side by Side...
Jenn-air side-by-side: freezer & frig cold on the bottom not top!
It sounds like 1 of 4 things...
1. It could be related to the evaporator becoming Iced over and when this happens it insulates the area iced over and the temp rises...this is caused from the defrost cycle not being activated...(Thermostat, or loose or broken wire)
2. There is a device called the thermistor which senses temp and Ice build up which will cause the unit to go into defrost...this could be bad.
3. The previous fixes may cost a little but not as much as the next which could be a restriction in the evaporator. This is serious and usually requires the replacement of the same...very pricey. Is there only 2 compartment or a pull out drawer for freezer foods..If so you could have an isolated problem in the upper freezer compartment which may be remedied without great cost
If your husband or yourself ..or a handy person can access the back of the freezer by removing the back panel I'm sure you will find either lots of Ice good..as far as cost to repair goes....or no Ice...bad...bad.. as far as cost to repair..the later falls in line with a restriction.
I hope I have helped....please rate me ...The Fang
Mar 27, 2009 | Jenn-Air JCB2280HES Side by Side...
WHIRLPOOL side by side freezer works fine but frig warm
You may think the freezer is fine, but stick a thermometer in to be sure. It should be around 0 degrees F. If not, you may have iced up coils. See some other posts on this site about getting to those coils and defrosting.
Jan 20, 2009 | Jenn-Air JCD2389G Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn air refrigerator problem
Couple things to check first is that your evaporator fan motor is running, located in the back of your freezer. open the door and listen for the fan some work on the door switch make sure you depress the switch to check it. If the fan is not running more than likely you need a new fan. The second thing is just look at the back of the freezer compartment and look for a layer of heavey frost if there is heavey frost then your defrost is not working, will need to manually defrost and probably replace the defrost terminator part of the heater assymbly
Feb 10, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn Air JCD2389GTW Refrigerator problem
change the adaptive defrost board located in the upper right corner of refrig under the panel. remove panel by pulling on panel towards you from the finger holes in the rear. remove two 1/4 inch screws and two phillips screws. defrost manually with hair dryer behind panel in freezer.
Jan 19, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Aire JCD2389GES Side by Side: Frig not cooling fully - freezer fine
i'm thinking that maybe an air duct is either blocked or the damper isnt opening. In the freezer compartment at the top right side there is a cover that is held in place by 1 screw. (look at item number 35 here). remove this cover and make sure ice is not blocking it up. if that is ok, then check the damper control to be sure it is opening and closing properly. The damper is located on the refrig side in the control cover (look at item# 8 here).
Dec 18, 2007 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
89 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
