Question about Sony PS-LX250H Turntable
Vestax o5 pro mixer channel 2 not working
Channel 2 on my 05 pro is not showing any input,no sound etc ive checked connections and everything seems ok,any ideas?
  • 515 Answers
Doe you get sound in from the headphones? If so, then the issue might be the volume fader for that specific channel.
If not, then the issue might be the input connections or input pc board the connections are soldered on to.
The fader can be self replaced, although complete disassembly of your unit is required. Not a hard task, but there are alot of jumper cables, and you have to be careful when putting her back together.
If it's the latter, then I would suggest taking it to a service center for repair.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 21, 2008
Hello! We have some problem whith 1 chanel, when 2
BOTH turntables and the same channel on each? If it's really really low and tinny that would probably be a failure to have/use a PHONO preamp (built-in and selectable on the Mixer).
Swap the channels coming in from the mk1200 and see if it stays with the mk1200 or with the left channel of the mixer.
There IS an outside chance you have flaky connections at the cartridge.
May 06, 2011 | Vestax Pmc07pro DJ Mixer System
The right output channel on the right side of my pmc 05 pro 4 has very low output. I can hear both right and left output channels in the headphones when I have the cue selected but when I try to monitor...
I assume you swapped thee output leads as well as the inputs which you di mention, to verify you amps and cables...
The Vestax schematic I have is NOT your same model, but the companies often re-use circuitry. In the schematic I have it appears that the two channels go through two levels of NJM2068L op amps.
In these two levels there is both a master gain control. It is important to know whether the gain control varies the output level of the right, even if it is low. Also in this gain control area is a master balance pot which varies the ratio of the left and right and is CAPABLE of taking either channel to near zero output... IF you have that control check it for sure !!! The pot is a dual employing both an A taper and C taper which is a reverse of the A.
The right tool for troubleshooting this is an oscilloscope, but first an inspection looking for board cracks around the output and pot area is in order.
Jan 01, 2011 | Vestax PMC-05PRO IV PMC-05 PRO 4 DJ MIXER
Had the amp 4 months and getting no sound apart from loud clicking noises when the speakon leads to the speakers are plugged in,ive gone as far as knowing its amp and not speakers/leads etc.its not had...
If the click is a one shot deal when you connect the speakers, I'd suspect that there is DC current on the outputs. Check using a DC voltmeter. You should read less than 0.5VDC. If you read more, there is a problem with the output section. Since this unit is new, it should still be under warranty. DO NOT open it up. If you read DC, return the unit for warranty service.
Please keep us posted,
Dan
Oct 27, 2009 | Vestax VDA1000 2-Channel Amplifier
My Power supply keeps blowing out
Sir,
You are suggested to buy power stabilzer because some the thing which blows the power supply is unbalance voltage. which Power stabilizer resolve . hope fully this would work.
Aug 30, 2009 | Vestax Pmc05pro-Sl 2-Channel DJ Mixer...
White noise in left channel on my Vestax PMC 06 pro-a DJ mixer
try it with nothing plugged in to the inputs, if there is no noise. most likely its the turntable, cd player, or whatever the input is is the problem. or try plugging the mixer into a different area of the house/room. its like if you were to put your cell phone by a mixer, or speakers.
Jun 25, 2009 | Vestax Pmc07pro DJ Mixer System
Behringer djx700 pro 5 channel mixer
Always check your cables and connectors on them to make sure the cable is good and the connectors are not loose. This sounds like a bad cable or connection between the line output of your mixer and input to your stereo.
Apr 23, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
The headphone jacks on my mixer(Vestax PMC-06 Pro A)not working
did you try the headphone jack in the back? also is the cue fader crackling when you move it left and right? also check if the cue fader is plugged in. if none of the above, check with your warranty
Apr 14, 2009 | Vestax Pmc06proa Thin DJ Scratch Mixer...
Vestax pmc-o5 pro 2
probably just a cold solder joint on the power plug inside the mixer. Check with a meter, then repair(resolder) if needed.
Nov 24, 2008 | Vestax Pmc07pro DJ Mixer System
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung HLN5065W 50" Rear Projection...
Vestax PMC 05 PRO MIXER master output is not working
More than likely the output PCB might be faulty, or the signal amp might be damaged. In either case, not an easy fix. As for service in the UK, try HARD TO FIND RECORDS - they have a pretty good service dept.
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.1200s.com
www.repairnyc.com
Jul 25, 2008 | Vestax CDX-05 Turntable
Sony PS-LX250H Turntable Logo
117 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
