LG WFT1071TP Top Load Washer
Problem for LG WFT1071TP Top Load Washer
LG WFT1022TP top loader washing machine
By Brakenjan on Apr 02, 2007
Once the washer start filling up with water, it does not stop and overflow.
Best Solution
posted on Apr 02, 2007
Very Helpful)
tresilla
Rank: Guru
Rating: 87%, 1612 votes
the system which controls water level is an air chamber with a small diameter pipe which goes to a pressure stat. when the correct level is reached, the pressure in the air chamber switches the pressure stat and cuts the water off.
the things to look for are:
gunge in the air chamber
split in the pipe.
faulty pressure stat
to test, get a similiar length of small diameter pipe and connect it to the pressure stat instead. with the machine filling, blow gently into the pipe and see if the water intake cuts off
Was this helpful?
Yes
No
Solution #2
posted on Jun 11, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
if the test of the pressure stat fails the test.the n.e.c models have a star screw in the top take that out and blow from the top it can push out gunk stuck in the stat itself.this problem happens manly because of bronken or block filters
Popular Solutions for LG WFT1071TP Top Load Washer
Questions and Unsolved Problems for LG WFT1071TP Top Load Washer
Do you recommend LG WFT1071TP Top Load Washer?
Answer
Answer
LG top loader throughs out an error during the rinse and spin cycle. What can the problem be?
Answer
Top Loader fuzzy logic 5.0kg LG washing machine (model wf-t502A) isn't draining. Not sure where to... (More)
Answer
how do you clean the filters onthe LG top loader Fuzzy Logic
Answer
my lg washing machine wf-s6607tc soon after start washing it stops then spin and drain lights comes.... (More)
Answer
Machine cycle but over flow as if load sensor is broken , The machine does not complete cycle and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , HI
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
