Question about Technics SA-EX310
Technics sa-ex310 no sound from surround sound speakers, front and center speakers work o.k. pushing test button results in good test from front speakers.
4 Suggested Answers
SOURCE: No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Posted on Apr 14, 2009
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
micromatikal
  • 2777 Answers
SOURCE: Need copy of manual for a Technics receiver
This was pretty tough to track down but I found it just for you!
http://service.us.panasonic.com/OPERMANPDF/SAEX510.PDF
Please make sure you rate my answer 4 thumbs up,
it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Posted on Oct 21, 2010
I have a Technics audio receiver, model SA-GX650. The front speakers work correctly, but the back and center speakers do not work correctly, i.e. no volume comes out of them. Would you please let me know...
Some receivers have adjustments you can make during set up to direct sound in various ways. There also may be configuration selections you can make using the remote. For example, enabling surround sound or selecting simulated stereo. The instruction manual should explain the various options.
Nov 23, 2014 | Technics Audio Players & Recorders
One Connector not working on Durabrand SA-SP9 Surround Sound
you have to test electrical out put, maybe loose wire inside or blown component
Jul 06, 2009 | Durabrand 5.1 Surround Sound Computer...
Center speaker is dead or what it can be on my Technics SA-dx930.
More than like, the center channel is turned off on your receiver. Please see page 16 of the manual, which is located here:
http://service.us.panasonic.com/OPERMANPDF/SADX930.PDF
The manual says to do this:
Turn on the receiver.
Press Speaker A and B button at the same time.
The word Setting appears then changes to Front
Press A to select Center
Press B to choose Large, Small or None for your center speaker.
After choosing Large or Small, press A again till you see Complete on the screen.
If this helps, please rate my response.
Mar 26, 2009 | Technics SA-DX930 Receiver
Can't get Surround Sound with Movie
hiya
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
Dec 15, 2008 | Technics SA-DX1050 Receiver
Technics SA-AX730
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Even though fused, your receiver has internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized service center must do this.] But, before you take it in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 07, 2007 | Technics SA-AX540 Receiver
Speaker Hook Up - Non-Technical (single) Female
bought the same amp second hand and had same problem as there are two seperate amp chips inside one for front speakers and one for the centre and rears it could be the actual amp chip that drives the front speakers has died as there is no built in speaker protection so over driving these speakers will result in the amp chip blowing . it may be something simple but it was not on mine had to buy new amp chip and solder in that sorted the problem for me !
Jun 02, 2007 | Technics SA-DX950 Receiver
Can't get surround sound to work. Only the front speakers.
you need to use the remote to do this. you can download a copy of the sa-ex310 manual at this site
http://www.usersmanualguide.com/panasonic/av_control_stereo_receiver/saex310
Mar 23, 2007 | Technics SA-EX310
124 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
