Question about Brother MFC-8440 All-In-One Laser Printer
Brother MFC 8440 makes very loud noise when printing/copying
It makes a really loud noise like it is dragging something heavy or has a jam but i've checked it out and its fine. What's the problem?
  • nwpacific Jan 06, 2009
    when turning on the printer it makes a very loud feeding noise
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Very commonly a broken gear on the right side of the fuser. Replace the fuser and this will fix your issue. Let me know if you need a part number and pricing.
Posted on Jan 15, 2009
Loud noise burning smell
please describe the noise? Burning smell like plastic?
It's a laser printer, so it's possible that the fuser is an issue. Is there a paper jam in the printer under the fuser?
Jul 17, 2014 | Brother MFC-8440 All-In-One Laser Printer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Brother MFC-8440 Check Originals
Check original normally means that there isn't an original in to copy. If it says that when there is an original it probably means that the paper sensor is jammed in some way.
Jun 26, 2009 | Brother MFC 8440 All-In-One Laser Printer
Making a clanking noise when printing
Could be a fuser gear is broken or a Toner gear is about to break. Needs TLC by a Authorized Tech.
Feb 11, 2009 | Brother MFC8440 Remanufactured Laser...
Not printing, says check original
Can be a document feeder jam.
Also can be that you are trying to copy an odd size original that it doesn't have the paper-stock for. in that printer it can be caused by not having the paper trays set correctly or using the menu to force it to try printing on something like legal size paper when it only has 8.5/11
Try resetting the printer with a power off and make sure the paper try is set to 8.5/11
Apr 24, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc8440 clicking sounds while printing
I had the same problem when I used a refurb toner cartridge, had to replace cartridge with oem for it to print. After a while started making same noise, had to take it in to have parts replaced. Now I don't take any chances on non-oem parts, it's not worth it.
Mar 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
NEW TONER INSTALATION
Non gen toner or fuser gear smashed, replace toner or fuser assy NO NEED TO YELL
Dec 26, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
menu * 2 8 6 4 super quick then 01, is full reset... warning all settings will be lost
Nov 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Nov 15, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
947 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
