Question about HP Officejet Pro L7780 All-In-One InkJet Printer
HP L7780 will not align and will not print in black. When I print out the self-testpage, it prints only in magenta. I have gone through 5 hours of BS with HP and nothing seems to work.
I just went through this problem. I called HP and they said to do a Semi-Reset, which is where you first make sure the plug is directly plugged into the wall outlet, not a power strip or battery backup, unplug the printer while it is powered on, wait 20-30 seconds,and while holding # and 6 plug the cord back into the printer, wait for a message or blank screen and then push the "On/Off" button. This has worked for me a few times now, although you have to go through some setup to get it back to where you like it.
Posted on Dec 23, 2008
HP Officejet Pro L7780 all-in-one, Windows Vista, set up as a wireless network printer, prints multiple copies of test page and also other documents, when only one is selected both at the computer and...
this is a simple problem, the technology that printer aligns its print head automatically by the reading the align page, if your printer head are not in good health/clogged align print wont come properly result align pending..When printer gets power on its prints align page till align completes. Go to tool box in system all programme, perform clean print head, check the quality of printer outs then ask to printer to align.. if its not completing replace print heads..
Sep 10, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
"alignment failed" message. Prints
First, try power cycling the printer (Turn it off, wait 5 sec, turn it on). If this does not resolve the issue, try removing the cartridges and reinserting them carefully.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Alignment of HP L 7780 failed. What are the steps to correct?
hello, you will need to run a cleaning cycle, you are looking for black printing, if not printing well, it might fail, if it does you will need #88 printhead. the black/yellow one. most times you will not need calibration to print, unless machine is stuck in that mode and won't pass. and won;t allow for print.
Oct 25, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
My printer has the message " alignment failed refer to device documantation". How do I fix this.
Use the setup button and scroll down to print reports, print the self test report and it should show all colors. If any color is not printing you probably need a new printhead for that color. Otherwise do a printhead cleaning until all colors print, and then alignment won't fail.
Oct 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
My HP Officejet Pro L7780 All-In-One InkJet Printer was jammed with paper. I believe I got it all out and now the display reads" Printhead problem- the following printhead has a problem: magenta/cyan...
There are two possibilities here Joanne, first, it could be a false error message or else second, the Cyan/Magenta print head has gone bad.Try the following:
1. Take the Cyan/Magenta printhead out. Remember, the printhead...not the cartridges.
Clean the copper contacts with a Q Tip, moistened with plain water. Wait till it dries, put the printhead back in.
2. If this does not resolve the issue, unplug the power cord from the back and press and hold the power cord for 30 sec. This will drain all the static charges. Plug it back after a couple of minutes and see if the error message re appears.
Jul 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Hp l7780 all in one
I just purchased a hp officejet pro L7780 all in one wireless trying to set up system - was suppose to have a poster sheet to guide me -- NO GUIDE POSTER - can i view one on line somewhere at no cost -
Nov 11, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
273 people viewed this question
Ben Johnson
