Question about HP LaserJet 4200n Printer
HP Laserjet 4250 printer black band 1 inch top of page
HI, I service these printers frequently but recently came upon one that intermittently prints a 1 inch horizontal black area across the top the page. I suspect that it has to do with uneven voltage going to the toner cartridge's primary charge roller since it's sometimes mottled gray instead of solid black. I already changed out the toner and checked the transfer roller contacts in the printer. Another tech mentioned to me that these 4200 series printer have had problems with the LVPS. Before I change out the LVPS i'd like to know if any other techs that visit here have had any problems similar to this one.Thanks in advance,Scott
  • jwaibel Apr 16, 2009
    Our 4250dtn frequently prints a dark 1" band at the top of the page.
    It does not happen on a predictable basis (every third, 5th or 10th page for instance) and does not seem to happen when the paper goes through the manual feeder but it does seem to happen 5-10% of the time.
    We have changed the toner cartridge and cleaned the unit but these fixes have not worked.
    Any suggestions that we could take care of (using the maintenance kit, etc.) or should I call a tech
Before replacing the LVPS, I surely would replace the toner and transfer roller at same time.
Posted on Jan 13, 2009
Why doesn't it print on LABELS at the top of the page?
I share a link please visit and follow step by step instruction.
I hope solved your issues.
http://ulearnoffice.com/word/printing.htm
Thanks,
HP Printer Support
May 30, 2014 | HP LaserJet 1020 Printer
Hp laserjet 2600n printer creates 1/2" wide band that you can almost see the print...like it is not getting toner in black color.
This often happens when cartrage has run past changing point. remove cartrages starting at top and CK for ink. Run cleaning page until clear
Jul 04, 2010 | HP Color LaserJet 2600n Printer
Hp laserjet printer is printing a large vertical
if the band is white, you may have a problem in your laser scanner assembly, if the band is black, you may have a problem in your fuser assembly
Mar 30, 2010 | HP LaserJet 1012 Printer
Hp P2015 printing black pages
it is the problem laser unite
Jul 22, 2009 | HP LaserJet P2015 Printer
My hp 4250 dtn printer is carying(repeating) about an inch of text down the page three times as if the fuser is not working on that particular portion only
From the servivce manual:
Basically:
1 Inspect the drum for scratches or
other damage. Replace the print
cartridge for defects that repeat at
37.7 mm (1.5 inches), 62.8 mm
(2.5 inches), 54.0 mm (2.1 inches),
or 94.2 mm (3.7 inches).
2 Process a printer cleaning page.
See Running the cleaning page
manually.
3 If the problem persists, and the
defect repeats at 75.0 mm
(2.95 inches) or 94.0 mm (about
3.7 inches), replace the fuser (see
Fuser).
Jul 09, 2009 | HP LaserJet 4250dtn Printer
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
Using XP sp2, excel 2000 and HP 4250 printer. Any
The print settings can be different for different programs. Open Excel and in the File menu, choose Page Setup. Click on Options, and towards the bottom is a setting that says Copies. Change this to "1" and hit OK, and you should be fine.
Hope that helps!
Mar 09, 2009 | HP LaserJet 4250n Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Hp laserjet 4250
try this
1.when the printer start print turn off the printer after the paper go on side the printer to make paper jam
2.open the printer and pickup the paper out slowly
3.see the print area on the paper if the black par appears on the paper that mean the drum unit faulty if not the fusser unit faulty
May 14, 2008 | HP LaserJet 4250n Printer
HP LaserJet 4200n Printer Logo
1,128 people viewed this question
Seeker5211
Seeker5211
