Question about KitchenAid KUDC25CH Dishwasher
Door still leaks after replacing bottom seal
Replaced the bottom seal along with the two plastic side brackets that come with the bottom seal kit. I used the suggested glue for the bottom seal but I still have water dripping out of the bottom of the door. It's as if the bottom seal is not firmly against the bottom of the dishwasher opening thus allowing water to pass through. There is no obvious way to adjust the door since the hinges simply rest on the hinge brackets. Any suggestions?
  • scullynm Feb 21, 2009
    have water pouring out the front? Any ideas? broken seal?? anyone with ideas how to fix the problem?
The bottom seal isn't actually a seal, rather it serves as a splashguard. I had the same problem with the same model and started by replacing what I thought was a seal located at the bottom of the door.
Check if the screws on the top half of the pump (located under the lower spray arm which needs removed first) have become loose. The screws were barely in the threads which caused a stream of water towards the door and leaked between the splashguard and bottom edge of the tub and onto the floor.door still leaks after replacing bottom seal - 0d084cc.jpg
Posted on Jul 02, 2009
Rear Door seal water leak
If silicon is working,I would go with it,silicone last a long time and it's working.
Dec 25, 2012 | 2001 Toyota Sienna
2005 xc70 volvo ceiling leak when it rain
Sounds like rubber seal is leaking, check the rubber seals along the side of the windshield and along the inner door. The seal can be easily replaced or patched with silicon sealeant.
Hope this helps
Jul 06, 2008 | 2005 Volvo XC70
I have a 1992 Honda Accord and whenever it rains, water leak through the speaker on the passenger side door and make a big puddle on the floor. Also the water leaks into a hole in the floor by the ECU
Not comming from the speaker! Make sure that the rubber door trim aound the door is intact and not damaged. Additionally, check the rubber seal on the outside of the window where it retracts into the door. These are the only 2 ways that water can enter through the passenger door.
Feb 11, 2012 | Honda Accord Cars & Trucks
Water on floor behind driver's side?
Your driver's side heater core most likely has a hole in it, or in the rubber lines, or you've got a horrible weatherstripping set.
Dec 31, 2010 | 1992 Volkswagen Passat
We have water leaking out of the left side of the dishwasher occasionally. About 1 in 3 loads will leak. Most of the time it is a small leak 1/4 cup or less but once it was a spray out.
One (or possibly both) of your door seals needsreplacing. It's more likely to be the lower door seal as these usually go first. This seal isn't visible like the goalpost seal that runs around the sides and top of the wash compartment. If you open the door, you can feel this rubber seal when you run your fingers along the bottom of the door on the inside. Be careful though, as there is often a build up of dirt down there!
I don't advise buying any parts until you are certain of where the leak is coming from. Identifying the source of the leak (and therefore which seal to replace) is relatively easy but the best way is to run a wash cycle with the front panel of the door removed. It's quite easy to remove, but you might need a T20 T-Star screwdriver to remove it. Sorry, I can't remember exactly what the fixings are on this model.
A simpler - but not always accurate method - is to check by look and feel. If the water seems to be coming from the sides of the door panel at the bottom when you run a wash cycle, it's the "goalpost" seal that needs replacing. These are easy to obtain and replace - they simply push into a slot.
To test the bottom door seal, run any wash cycle and, when it's finished, stand to the side of the washer and open the door. There is a white plastic panel under the door. Have a feel around on top of this. If it's wet you probably need a new lower door seal. These are much harder to replace as it involves removing the door panel and partially releasing the hinges. I don't recommend this as a DIY fix unless you are competent, confident and have good instructions - i.e a service manual!
Whichever seal you need, they cost around $30 / £20 each.
Please rate this solution if you find it helpful. Thanks.
Oct 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a 97 Toyota Camry and have had a leak on the drivers side for over a year and can't trace it. I have been told it was the windsheil and replaced it, have replaced under plug, have tore up carpeting...
blocked drain holes at the bottom of the door
missing plastic membrane that seals off the door openings before the trim is put back on door opening seals broken or not sealing properly
Nov 28, 2017 | 2007 Jeep Wrangler Unlimited Rubicon 2...
How to replace door seal of Hotpoint WF860 washing machine
Hi, This is a very simple and straight forward job. First turn off the washing machine and remove the plug from the wall and earth the plug on the cabinet of the machine to remove any residule current in the machine. Remove the top of the machine with the screws at the rear of the machine. You can now look in the top? Open the door and take off outer door seal clip ( look and you will see how ) If it is a plastic clip it will have a small cut out in the side for a small screwdriver to be put in a pushed open. It could even be a small spring that is laying in side the small lip of the door seal. You could now attempt the removal of the door seal if you can see the inner clamp to get a long screwdriver onto the screw! If not now remove the soap drawer. Remove screws from around the soap drawer and slide the facia to the right and it should all be off.. Then you can remove the three screws that hold the front on along the top and the same along the bottom edge of the front panel. This then will allow you to take off the front panel and have better access to the door seal. Then once you have replaced the door seal you just need to replace as you took off..
Good luck................
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Frigidaire Dishwasher Leaking
I just found a service release number for my Frigidaire dishwasher that says it applies to Serial numbers TH632 through serial number TH737 made in 2007 for a replacement kit for the door seal at the bottom of the door. The bottom door seal has been changed, adding side seals that restrict the water surge from the center spray arm. The part number for the new seal is p/n 154588201. This seal can be replaced without removing the dishwasher or either of the door panels.
The seal is located on the bottom of the inner door panel and appears as a cream colored flexible
rubber blade bonded to a milky white colored plastic strip. To remove and properly install
replacement follow the instructions carefully.
1. Replacing this seal can be accomplished without disconnecting power from the unit.
Always use extra care when electrical power is present while serving an appliance.
2. Open door all the way down and remove lower rack. Set rack aside to a safe location.
3. Locate the seal on the bottom of inner door panel. Facing front of unit, the right side of the
seal can be pulled down slightly to facilitate removal.
4. Pull seal straight into the tub from right side.
5. With seal removed, and before installing replacement seal, locate the channel in inner door
panel that the seal mounts into. Locating this channel before installing the replacement can
make this procedure easier.
SERVICE FLASH
DW071
6. Place the new seal on a flat surface and measure from the bottom of the seal, (See Figure
1 to determine bottom of seal), up 3/8 "of an inch and place a mark with a pen or marker on
both ends (See Figure 2). If needed, scribe a straight line between these two marks this
will give you a guide when installing seal into the inner door panel.
7. The seal can only be installed one way. The end that holds this seal into the inner door
panel has a ½ inch notch cut in the right side. This notch allows the seal to be installed
around the end of the inner door channel that holds the seal.
8. Line up the seal along the bottom of the inner door panel and start from the right side, push
the seal into the door channel to the line marked in step #6.
9. With seal in place close the door, the tub will align the seal as needed.
10. Reinstall lower rack and operate unit to check for leaks.
If leaks continue to occur at the bottom corners, order Splash shield kit 154701001 for
dishwasher.
Before installing the kit remove and reinstall the lower door seal. To install the lower seal make
sure you measure up from the bottom of the seal 3/8 of an inch and mark the seal, do this on
both ends. This locates how far down the seal needs to be before closing the door. Do not
install this seal without measuring it first. After the lower door seal has been re-installed then
install the splash shields according to the instructions accompanying with the kit.
Sep 18, 2007 | Dishwashers
Open Questions:
See all KitchenAid KUDC25CH Dishwasher Questions
KitchenAid KUDC25CH Dishwasher Logo
594 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
