Question about Saeco Magic De Luxe Espresso Machine
Hello and good morning, I have the Saeco Magic model which has been absolutly fantastic, in the last couple of days my machine has been making coffee that has been very watery? How do I fix and could it be as something as simple as descaling? Please HELP, I've got 40 people coming over for Christmas...
    Problem Solver:
  • 8 Answers
You don't say whether your using ground coffee or beans if using beans chek that no one has altered the grind adjustment on the bean hopper. If using ground coffee it could be that the grind is too coarse not allowing the machine to extract the coffee.
Posted on Jan 09, 2009
Coffe Machine Saeco Magic Comfort
the coffee beans grinder is too fine .Turn to next number,
Oct 29, 2013 | Saeco Magic Comfort Plus Espresso Machine
I need to replace the coffee dispencer part where the coffee actually comes out of into the cup on my 1999 Saeco Magic Deluxe, the part is $13 AU, is this an easy part to fit?
There are a number of Saeco Magic coffe machines from this company.
The best site for parts I have come across is listed below, I suggest that you look at this site to find your correct model:-
partsguru.com/SaecoBrewGroup.html
Regards
Alan Hood
ami-man
UK
Apr 09, 2010 | Saeco Magic De Luxe Espresso Machine
My Saeco magic grinds the beans, but no coffee comes out. Sometimes it makes one cup, and skips. Other times, I grind the equivalent of 8 cups of coffee without any cups of coffee coming out.
HI
When a machine grinds but doesn't make any coffee there are a couple of things.
If the grounds are wet in the dredge drawer, then you have a plugged brew head and need to clean it.
If the grounds are dumped dry into the dredge drawer, then you have an overcharge and need to adjust the dosing lever back from the full charge. On your machine it is inside the door at the top center. Pull the lever back towards the front 1 click. Then try again.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Comfort Plus machine has message "Ventillate" how do you clear this?
open steam knob and water need start going on steam wand keep going couple minuts and you will see machine is ready,if you still have same problem thats mean your flowmetar is not good
Aug 03, 2009 | Saeco Magic Comfort Plus Espresso Machine
Saeco coffee machine
make sure that the brew group and door are close or dump box ect
Jul 08, 2009 | Saeco Magic De Luxe Espresso Machine
No pressure build up to make good coffee
Turns out it was just old coffee holding the group brewer together. Ended up replacing the whole handle which cost AU$44, so not too bad really. It's like new now.
Nov 25, 2008 | Saeco Magic Espresso Espresso Machine
No power to boiler - cold coffee
Heating element on boiler is defective. Depending on which model magic you have there might be a seperate boiler for the steamer. No power to heat plate would suggest heating element on heat plate has gone bad or worse case there's a malfunction on the pc board of some sort as everything is fed to it. If it is the board, unless it is the magic redesign (rectangle board vs triangle board), it cannot be replaced as saeco does not carry that part any longer.
Nov 20, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Machine coffee grinds drawer overfills with water
Hi The thumb screw on the brew unit is stripped. If you remove the brew unit and you have water where the thumb screw is its stripped. you just need to remove the old one and replace it.
Oct 13, 2008 | Saeco Magic De Luxe Espresso Machine
No coffee comes out from the coffe machine
The grind may be too fine. The Brew unit is plugged and needs service. The spout joining the boiler to the brew unit is broken. The unit may be plugged with scale.
Jul 24, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
216 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
