It runs well on the battery, but will not start up properly if on battery only.
The problem is a flat BIOS battery. This battery keeps the Date & Time and other laptop setting stored in the BIOS. When the battery is flat then these settings are lost when you switch off the laptop.
You need to replace the BIOS batters thn go into the BIOS to set the Date & Time then you will not have further problems.
I looked on line at a manual and reached that conclusion. I went for a battery and the only ones readily available were not attached to the wires and needed welding. I am now waiting for a wired battery replacement that is on order. Thanks so much. A $5 fix doing it myself.
I was asked to rate the reply. Too early to be sure as I am still waiting for the battery, but I am confident that the suggested solution bolstered my confidence in my planned solution I decided on by researching Thinkpad's web site.. Thanks.
Try this Method:
One of the most common methods to reset the BIOS password is to remove or discharge the battery on the computer's motherboard. If the power to the battery is lost or drained, the BIOS configuration will be reset to the factory state with no password. System settings made to the BIOS will also be lost.
Step 1 - Turn off the computer and ensure it has no external power (ie unplug the power cable. If it has a battery, remove it).
Step 2 - Open the computer's case or box.
Step 3 - Locate the computer's motherboard and look for the white silver button battery on the motherboard.
Step 4 - If the battery is not soldered to the motherboard, remove it carefully and wait for approximately 30 seconds.
Step 5 - Put the computer case back together and boot the computer.
Step 6 - If the "CMOS Checksum Error-Defaults Loaded" error message is displayed, the BIOS password has been reset.
In the event the CMOS battery is soldered to the computer's motherboard, you will want to seek a different method to reset the BIOS password on the computer.
