Question about Sunpak (SDPF-070AW-0US) Digital Picture Frame
I just got the frame and it won't power on.
I plugged the power cord into the frame and turned the switch to on and it won't do anything.
    Problem Solver:
  • 5 Answers
Have you already got pictures on there.
It won't display unless it's got pictures. On my copy i plugged my Frame into my computer. then pushed in a memory card to the Frame and dragged and dropped into the frame itself.
If there still isn't picture then there must be a setting on the Frame in which can make them go through the pictures.
Posted on Dec 20, 2008
My 10" digital not working it comes on but not reponding the icon dont come up its not doing anything please help
hi
try to see if you have a reset hole in the back or sides if not then try to reconect the battary or to empty the battary .
May 17, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
It won 't turn on
check your power cords, check your outlets, check your surge protector, check the switch on the back of the pc. there may be a black toggle switch with a circle and a line, make sure it's flipped to the line side. if all that is normal, unplug the cord from the computer and open up the case. look at all your power plugs and make sure they're all secure, try and reseat the 1 or 2 main plugs, there should be a rectangular 12 pin plug and maybe a 4 pin plug. unplug them and then plug them back in. put the case back together plug it in, and give it a go. if still nothing then you have to troubleshoot whether the power supply is junk or if your motherboard died. we'll move on to that if it comes up. good luck!
Jan 30, 2012 | Gateway 300 X PC Desktop
Pro form 365 won't start
Dear Sir:
I will help you, please do the exact step:
PROBLEM: The power does not turn on
SOLUTION: a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor is plugged into a properly grounded outlet (see page 10). Use only a single-outlet surge suppressor that meets all of the specifications described on page 10. Important: The treadmill is not compatible with GFCI-equipped outlets. b. After the power cord has been plugged in, make sure that the key is fully inserted into the console. c. Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch back in.
Finally: check, the breaker from the home, if there tripped, check this, and Reset.
I will recomend when you finally set up, install Stabilizer Voltage, is cheaper us$15,00 aprox
Thank you in advance, sincerely.
Blessing, if you need additional help, please contact me.
E.CUADRA MANAGUA, NICARAGUA.
Sep 26, 2011 | Proform Crosswalk 365 Console Treadmill
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
How do I turn off my Reebok 8050 ES? I can not figure out how to turn it off when I am not using it.
Plug in the power cord. Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset
Apr 20, 2010 | Reebok 8050 ES Treadmill
Toshiba Satellite A305D-S6848 HAS NO POWER. NO LIGHTS COME ON AND I PLUGGED THE POWER CORD INTO ANOTHER TOSHIBA AND IT WORKS. NOT A POWER CORD PROBLEM. NO FANS RUN OR ANYTHING WHEN I HIT THE POWER BUTTON....
TRY TO REMOVE THE BATTERY AND JUST PLUG THE CHARGER ON IT AND ON POWER. SWITCH IT ON. IF IT TURNS ON THEN YOU SHOULD KNOW THAT YOU NEED A NEW BATTERY OR IF IT DOES NOT, TAKE IT TO A COMPUTER SPECIALIST TO CHECK ANY HARDWARES THAT ARE NOT FUNCTIONING.
THANK YOU
WONDER
Oct 29, 2009 | Toshiba Satellite A305D-S6848 Notebook
My window unit fell out of the window and hung by the power cord that was still plugged into the wall. I was able to grab the cord and pull it back up. I reattached the power cord and now every time i turn...
Its most likely is not the switch. It is most likely the cord though. Due to the excess strain on the cord it has probably cut through the rubber coating on the wire and connected to the frame and grounded the hot lead. Fix the cord and you may have it handled.
Jun 15, 2009 | Frigidaire FAX054P7A Wall/Window Air...
7 inch digital picture frame
Where do I go to have my picture fram serviced???? It has worked fine. Then it shut off and will not turn on again. I pulled the power cord and left it off for a couple of days and then plugged it back in. That had worked before and now does not.
Jul 15, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Need replacement motor
Before trying top replace anything, make sure you have power at the motor from the cord.
If you have no way to check for power, unplug and change the cord to any other you have around.
That will assure that the cord is good or bad.
Feb 16, 2008 | Dryers
Sunpak (SDPF-070AW-0US) Digital Picture Frame Logo
375 people viewed this question
Top Sunpak Photography Experts
Tony
Jay Plesset
richie46
Are you a Sunpak Photography Expert? Answer questions, earn points and help others
