Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
Keybrd locked keyboard is connctd and hot keys wrk i.e. the email key all other keys make a tick sound only and do not function tried cntrl l and cntrl alt f12 no luck help.
  • 51 Answers
Press shift key 5 times message will be come go to setting and uncheck all 4 option and apply problem will be solved. pleaseee rate this solution thank you.
Posted on Dec 22, 2008
My email n password dont match, how can I fix it?
The procedure to troubleshoot email account login issues may vary depending upon your email service provider. So, to let us suggest you a specific solution, can you please share with us the name of your email service provider?
In the meanwhile, we recommend you to make sure that all the keys on your keyboard are functioning properly. If one or more keys are jammed or have stuck up, the keys that you hit may not display characters correctly on your login page. Also, make sure that the functional keys like Caps Lock and Nums Lock are On or Off only when required. To make sure that the keys on your keyboard are working fine, you can first try typing your email ID and password on a Notepad or Word Document and see if they come up correctly. If the keyboard is working fine, we suggest you to try typing your email ID and password slowly (if you have not done this already). Also, give special attention to characters like 2 or Z, 0 (zero) or O, 1 or I, 5 or S, 8 or B etc.
If one or more keys on the keyboard have become malfunctional, try logging in to your account through some other device (if you have not done this already) or consider using a different keyboard (if possible).
You can also try onscreen keyboard by press and hold the Windows key and hit the letter R. Type in OSK and hit enter. Try using the onscreen keyboard if the keyboard is not functioning correctly.
GuruAid.com
Jul 17, 2014 | Computers & Internet
Keyboard shortcut keys
By default, the shortcut key for paste is "Cntrl + V", where copy is Cntrl C, and cut is Cntrl X.
If you'd like to program a shortcut key for a program, say, notepad.. Find the notepad icon you use to launch it, right click, properties, Shortcut, shortcut key.
Jun 14, 2013 | Lenovo Computers & Internet
Why would CNTRL-ALT-DELETE not work when I need to lock my computer? Where is the Num Lock located on this keyboard?
Num lock is located juz above the 7 num key on the num keypad. Try using control alt del key on another system and check if it works or not.
Aug 25, 2011 | Logitech MX 5500 Revolution Keyboard
How to unlock keybrd of sony vaio
Holding down shift key for more than 8 seconds will lock the keyboard and it will stop responding. But if you keep pressing keys for few seconds you would be able to type in but it will be very slow. Plus, it will produce a nasty sound.
To get around this, go to start and then settings, then control panel and then finally accessibility options. Make sure all the 3 boxes are unchecked.
Nov 15, 2009 | Toshiba G83C0001K210 Keyboard
Function Keys
If your computer has had its mainboard switched, or has been hardreset, you might have to change the setting for your function-key ( Fn ) in your BIOS.
Try this:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=dk&lc=da&dlc=da&docname=c02035108
Jul 02, 2009 | HP CPQ175KB Keyboard
JUST HLP PLEASEEEEE
Sounds like your keyboard is sticking
Unplug the keyboard and do the following
Look on the bottom you should see some screws, remove the screws and leaving the keys facing down, pop the two pieces apart.
Leaving the electronics aside you can now continue with the following instructions
Ok, once you have the two pieces, all of the keys should stay in there proper place, take and soak that in the sink with some soap and water.
Moving all the keys to get the water to flow through.
Then dry off the Keyboard and vacuum all the excess water off, then replace and screw back together, you should be good to go.
I wouldn't recommend a dishwasher, this could get to hot and melt the keys
Apr 24, 2009 | Gateway 2520796 Keyboard
Wierd synbuls
You may have activated a shortcut key on your keyboard such as the Fn (function) key. It looks like this
Fn and usually situated on the bottom left hand side of your keyboard near the left hand cntrl button.
Some function keys when pressed once remain on. Once they are on they can cause different symbols to appear in place of the normal keyboard ones. If you press your Fn key again and then try typing on the keyboard once again it may help fix your problem.
I hope this helps
Cheers
john
Nov 16, 2008 | Compaq Keyboard
When ever i press certain symbel keys its wierd
I hope this helps
Cheers
john
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
100 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
