Question about Simplicity Zig Zag
SZA - 515 Sewing machine Name?
It has a lever on the base that can switch from sew to darn. Who made this? The Name label is missing. Thanks
  • 319 Answers
SOURCE: tangled thread inside takeup lever in pfaff 1475cd sewing machine
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
mohammed387
  • 1952 Answers
SOURCE: lever is stuck in reverse
If the stitch length bar, which is located on the right side of the machine, is in the up position move it down to where the numbers are. Those numbers are referring to how many stitches the machine will sew in an inch. Therefore, if you put it on 10, your machine will sew 10 stitches per inch. It being up will cause your machine to go in reverse.
Posted on Jul 26, 2009
  • 40 Answers
SOURCE: i need a manual for a butterfly sewing machine
www.janomestuff.com answer it all
Posted on Sep 15, 2009
SOURCE: Reverse Lever isn't working...
Most likely the "dogs" inside the lever are broken off. Oil/grease on the metal rod cause chemical attack to the plastic lever and the "dogs" break. Singer should know to degrease this rod before assembly.
Posted on Nov 06, 2009
Denim hole repair what setting?
Depends on the size and type of hole. If it's large with missing fabric, I back the hole with matching fabric, then zig-zag several times around the hole If it just a tear or slit that can be pulled back together and repaired, I use a darning stitch to connect the torn pieces.
https://www.dummies.com/crafts/sewing/mending-holes-and-rips-in-your-clothes
Learn How To Mend Clothes with Machine Darning Sewing Beginner German
Darning with Sewing Machine
Backstitch Practice Tutorial How to Darn Jeans Cucicucicoo
Jul 16, 2018 | Sewing Machines
How to lower the feed dogs for free motion sewing on model # 16782
There are most likely some numbers missing from the model number you provided. Usually, there is a 3-digit beginning number, ie 115, 385, 401...
I am unable to find model information based on your number, but you can most likely get a user's manual through Sears or try searching the internet (Make Model manual), ie:
Kenmore Sewing Machine Manuals Instruction and Repair Manuals
Sewing machines generally have two ways to disable feed dogs. One way is a lever or knob on the machine itself that physically "drops" the feed dogs so they are below the needleplate. The feed dogs will continue to operate but since they are below the sewing surface, they will not have an effect on the fabric movement. The other way is an accessory that attaches to the needleplate which covers the feed dogs and creates a flat sewing surface.
Another item that is important for free motion quilting is a darning foot or free motion foot. These presser feet are physically shorter in height than a standard presser foot. This means the darning foot, when lowered, does not apply "pressure" to the fabric when it is lowered. It, instead, provides leeway between the presser foot and the fabric so there is room to manually maneuver the fabric while stitching.
You'll just need to CONFIRM that the presser foot shank is correct for your machine (low shank, high shank, slant shank).
There are probably a multitude of designs available for your machine, either Kenmore or generic brands. Once you've determined your machine's shank, it would be a personal decision as to the design you'd prefer, which could be metal or plastic, closed, open, or clear see-thru as well as various shapes, round, oval, etc. There are also some feet that are spring-loaded so they "hop" while you stitch, or feet that are solid.
These are examples of different darning/free motion presser feet.
Darning Foot Low Shank 4021
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Amazon com Tinksky Sewing Machine Open Toe Metal Quilting Embroidery...
Free motion Darning Quilting Sewing Machine Presser Foot Fits All Low...
Nov 27, 2016 | Kenmore Sewing Machines
Where can i find a copy of Nelco sewing machine model SZA 232 manual
try to google the make and model of the sewing machine
Nov 21, 2014 | Sewing Machines
Can anyone supply me a manual for an olympia sewing machine model SZA-31F
email these sites about a manual
sewvacdoctor.com
a1sewingmachines.com
sewusa.com
Jun 08, 2012 | Sewing Machines
How to use a darning foot
Remove yourcurrent presser foot from your sewing machine, and attach the darning foot asyou would any foot. Darning feet look different, depending on the manufacturer,but most will maintain a "C" or "O" shape using eithermetal or clear plastic at their bases.
Drop the feed dogs, or use a cover plate on your machine if feeddogs are not available. If this is not possible, adjust the stitch length ofyour machine to zero or as low as your machine will allow.
Slide your fabric or quilt sandwich into place below the darningfoot. Lower the lever of the darning foot, and hold onto the upper thread withone hand.
Take one complete stitch, and pull up the upper thread to bringthe bobbin thread to the surface. Take multiple stitches in the same place tosecure the threads.
Run the machine as you free-motion sew or quilt your fabric piece,using your fingers to move the fabric instead of the feed dogs, until yourstitching is complete. Replace the darning foot with your preferred presserfoot when finished.
Read more: How to Use aDarning Foot ' eHow.com http://www.ehow.com/how_5143471_use-darning-foot.html#ixzz1AprkDyhm
Thanks for rating
Good luck
Jan 12, 2011 | Sewing Machines
Feed teeth have dropped down
Hi. Benieth the free arm there is a lever that you can switch from left to right. This raises and lowers the feeddogs for normal sewing and darning. Possibly you need to flip that switch lever. If that doesn't solve it then the freearm cover on the bottom needs to be removed and the feeddog mechanism cleaned and oiled. Could be stuck.
Good luck. Hope its the easy fix.
Rick
Jan 21, 2009 | Bernina Bernette 75
Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Sep 20, 2008 | Sewing Machines
Simplicity Zig Zag Logo
71 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
