Question about HP LaserJet 1020 Printer
Vertical smear on the full right side of page 3-4 cm
My printer has been stopped for a while and I have recently began using it again.
The problem is that the entire page, on a vertical right side strip of about 3 to 4 cm is entirely smeared, especially on the areas where there should be. You can also see a very noticeable amount of toner on the top edge of the paper (the edge that first enters the printer).
It's like it was a brush smearing the paint right after printing.
I can also notice a very slight indentation that separates this smeared vertical band and the rest of the page, that prints fine.
Thank you
  • zemanel752 Dec 20, 2008
    I dismantled the printer and got to the conclusion that it was the printing band that was damaged (small peaces kept tearing up), so it has no solution.
maverick24
  • 56 Answers
SOURCE: print jobs smeared
Hi Are you using OEM or rebuilt toners? If your using OEM and your able to smear the ink with your finger more than likely you have a fuser problem?. If your using rebuilt cartridges it could be the cartridge. Good Luck!!
Posted on Dec 03, 2007
EPIJAB
  • 89 Answers
SOURCE: hp laserjet 2200d
If the toner smears after the page comes out of the printer you may need a new fuser. The fuser is the heating unit in the printer and can usually be seen from opening the back door. Check and see if it has a line worn down the same side as the mark on your pages.
Posted on Feb 15, 2008
SOURCE: Ink smears ,
You need to clean the print head until the smears clear up
Posted on Feb 19, 2009
  • 199 Answers
SOURCE: right edge is smearing - HP 3030 laser
yes.teflon sleeve
Posted on Sep 25, 2009
SOURCE: the paper comes out crumpled with smeared ink on one side
the problem is the fusing film of the printer. go to a store and try to change the fusing of your printer. sayedelyaskavesh@gmail.com
Posted on Apr 04, 2010
White vertical band in Cyan and Black
try to clean the laserwindows of the printer.
Mar 25, 2013 | Xerox Phaser 6125 Laser Printer
I'm getting 2 grey vertical lines on the entire page of each print. They are spaced 5.5cm from the right hand side and 5 cm from the left.any suggestions on what I should try to clean on my Epson...
Please do the following:-
1. Switch off the printer and remove the toner.
2. Swap with some white cotton waste.
3. Then reinsert the toner and try again.
4. If you are getting the same problem, please replace a new toner
Jul 23, 2011 | Epson ACULASER CX11NF All-In-One Printer
Konica Minolta 2300W ink smears
check the transfer belt..there is a reason why some used printers are sold on ebay!
be prepared for sticker shot.
Apr 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Vertical line on copies
A vertical line on laser copiers which are the same lenght apart on each indicates a dirty or defective toner cartridge or dirty or defective rollers. Take the cartridge out and wipe the rollers with a soft cloth. If the streaks continue then the rollers inside the cartridge or damaged. You will need to replace the toner cartridge. Let me know if you have any questions. Please rate this solution with 4 diamonds.
Mar 29, 2009 | Dell 3010cn Laser Printer
Printer smears on cold print
The toner cartridge sounds like the problem to me. Did you refill it? Or have it done? It sounds like an incompatible brand......toner is very model specific, and not just 'any' will do, and it often doen't mix well with the remaining toner i the cartridge if it is not completely disassembled and cleaned out. Just curious
Mar 16, 2009 | Brother HL 5250DN Laser Printer
My Hp 1020 printer is printing full black pages.....
is this a laser printer? have you replace the toner cart?
Dec 12, 2007 | HP LaserJet 1020 Printer
Lost reverse side printing option
Yepperz
The double sided printing option relies on Status monitor working correctly. If information cannot travel from the printer to the computer, the option will be greyed out.
Make sure you have a direct connection to the computer without any hubs. If that doesn't work, try the following.
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Sep 07, 2007 | Epson Stylus R265 InkJet Photo Printer
HP LaserJet 1020 Printer Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
