If you use a humidifier you will have to fan your fruiting chamber much less. A cool mist humidifier provides almost ideal humidity levels for casings, and more importantly, constant gas exchange.
If you're not using any lights or pumps in your aquarium I advise
you to get an aquarium fan it will definitely do. If you do use thing such as
lights and water pump that warm up your tank you should definitely get a
chiller, try the Oceanic Aquarium Chillers.
An in-line water chiller
is equipped with internal cooling coils. Water is pumped out of the aquarium,
into the chiller where it is cooled, and then back to the aquarium again. An
in-line chiller can be placed away from the aquarium and is therefore easier to
hide.
There are many ways you can cool-down your aquarium. You can use a
simple fan that runs on timer along with the lighting. You can use a
thermoelectric chiller. You can use a refrigerant base chillier and there are
also some alternative methods.
The cooling fan main purpose is to cool off the light by inflating
air outside the tank and therefore cooling your whole aquarium.
