Question about Briggs & Stratton 15,000 Watt Home Standby Generator
15KW liquid cooled died when 240V.applied to terminal strip
I am a master electrician, helping a friend, hooking up a used generator. We are using this in manual mode.When LP gas was hooked up I simply swithed it on and it ran fine. I had also ran a 12-3 romex to unit for battery & block heater. I mistakenly wired this to a double terminal strip(I believe is item#52),on right side of control box. After I killed unit, I traced (2) small blue wires to DPDT switch(item 19 p.n.76020).I know now that this must have been a remote switch. Besides replacing auto/manual switch, what else did I possibly damage?. We tried jumping solenoid, for a second, and it cranked motor. I stopped before I caused more problems. 30 amp fuse was fine. Are there any other fuses? We had a major ice storm in NH, and I have been hooking up mostly portable units all week.(Gentran switches).I was mortified to kill this genrator & hope for a quick solution. Jean L. Landry/ J.L.Electric
  • 1 more comment
  • jllandry Dec 20, 2008
    I know I put 240v. to this switch. Will replacing switch slove problem? This specific to a Generac/Guardian LP gas 15KW standby generator.
    It is a Generac Guardian 15KW LP gas standby generator. I only need it in manual mode. The unit is used, so I don' t know exactly what year it is but it looks new, and I believe the control box is the same for most all the lp gas models in this power range (10KW - 25KW)
    Can I use a DPDT switch purchased from Radio Shack? I did look at the ratings for this switch.The toggle works as such, on/off/on. Is this an industry standard for such a switch? The ratings on side of switch were (15 A 125V. or 10A @250V.)I just don't want any more surprises!
  • 1,512 Answers
Hi
I would replace the switch with the radioshack equivalent. If it served as a part to the remote ignition on off circuit. Check for any volts to the wiring on the switch. I expect that it is a switch to 0v , you should have some voltage on one of the wires. If you have feed a battery voltage up to it, then there may have been some further damage in the ignition circuit. Change it out and see what happens. I give you good luck and it will work out for you :)
regards robotek
Posted on Dec 20, 2008
  • Graeme Ross
    Graeme Ross Dec 20, 2008
    Just as ToyotaEd has already pointed out. :)
  • Graeme Ross
    You could get some decent information from here
    Master:
  • 479 Answers
Yes u can go for radioshack switches . thanks.
    Sergeant:
    Champion:
  • 304 Answers
What is the exact model name of the generator.?
  • 1,861 Answers
The DPDT is most likely the switch that allows the transfer switch to activate the generator. You also pulled power where you should not have.
  • Toyota Ed Dec 20, 2008
    Replacing the switch should fix the issue.
    The center contact is cooked. I would NOT bypass the switch to verify operation.
    The Radio Shack switch should be sufficient. The ratings are acceptable. Inatall it and please get back to me, works or not.
What size wire to hook up a 15kw generator to my house
At 240v, a 15KW generator will produce appx 62A or 31A per 120V leg. Therefore allowing for some overload, a conductor sized for 35A per leg would be adequate, but you should verify local code requirements.
Aug 28, 2014 | Generac Electrical Supplies
Battery keeps dying
charging system, alternator/coils.
Apr 09, 2014 | Generac GUARDIAN Series Liquid-Cooled...
I purchased a generac 22 kw 3 phase 120/240 volt generator. I was surprised to find that it had a wild leg. Can i change the leads on the stator output to eliminate the high leg and get straight 120/208...
This unit is wired 120-240V 3 phase Delta. if you are using on it 120/208V 3 phase application it will need to be re-tapped. If you are using it in a home 120-240V single phase it will need re-tapping, Do NOT just use 2 legs, as this will cause rotor imbalance and wear out the rotor bearings, and odd ball currents to flow. If there are 12 leads coming off the stator it can be reconnected. If not you are stuck with it, except by using a transformer
Dec 15, 2013 | Generac Generator QT02224JNAX QuietSource...
Gnerator has dropped in output
Check the Power output switch is set to 240v. Yours may not have one because you haven't said what make and model of computer the motherboard is in. Incidentally computers don't generally have generators.
Oct 31, 2012 | Computers & Internet
I'll try to keep this short, however i have very limited electrical knowledge, so i will try to explain my situation as best i can. i bought a pramac es 8000 used a couple years ago. when we built our...
Ground the generated it's self. I had a similar problem after a storm once. First on the generater itself find a flat peice on the frame say by the motor. Sand in down to mettal. Put a self tapper screw in. Now get a 5' to 6' peice of 10 gauge bear copper wire. Attache it to the generator and shove the rest into the ground. Now it's grounded and It took care power surges when I did it. Hopefully this will help you.
Mar 30, 2011 | Pramac Honda 8000 Watt Generator
I have a coleman powermate maxa 5000 er Generator. Model # PM0525202. The powercord plug came loose and burnt the plug and the receptical(240). I replaced the plug and receptical and I am not getting...
If this is the model I am thinking of, there are 3 outlets. One 240V (L1, L2, Neutral and Earth ground. Some models use a 3 terminal receptacle that combines Neutral and earth.), one 120V receptacle (L1, Neut, earth) and another 120V receptacle (L2, Neut, earth).
If you verified fuse and circuit breakers are good, turn on the generator and verify you get 120V on each of the two outlets. Measuring between the narrow blades of the two 120V outlets should be 240V.
***Shut off the generator.
With a test light or ohmmeter, check continuity from the earth terminal of 120V outlets to 240V outlet. Likewise for neutral (wider blade on 120V outlet). Lastly, check continuity from Narrow blade of each outlet to the 240V outlet.
I suspect that you miswired neutral and earth. On a 4 wire PLUG, it is customary to connect earth and neutral.
Work safely so you can give feedback.
Aug 30, 2017 | Coleman Electrical Supplies
My EH40 is not supplying power to the water heater. I hooked the power line in to posts 1 and 2 and I hooked the load out to posts 4 and 6. When I use my power checker it reads no power to posts 3,4,5,...
I have an EH 40 sitting in front of me right now.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
The link above shows correct 240V water heater timer wiring for EH40
Link below shows an overview picture of EH 40 connected to 240V water heater
http://waterheatertimer.org/images/EH40-water-heater-circuit-5.jpg
http://waterheatertimer.org/240-v-water-heater-circuit.html
EH40 has a 240V clock.
Terminals 1 and 2 send power to the 240V clock
Power to the clock terminals do not pass through timer to any other terminal
How to wire EH40 for 240V
240V line has 2 hot wires from breaker box.
Lets call these wires Hot1 and Hot2
These wire are interchangeable on 240V circuit
Hot1 connects to terminal 1 with a jumper to terminal 3 (or connect to 3 and jumper to 1)
Hot2 connects to terminal 2 with a jumper to terminal 5 (or connect to 5 and jumper to 2)
240V circuit has 2 wires going to the Load
Let's call these Load1 and Load2
These wires are interchangeable on 240V circuit
Load1 connects to terminal 4
Load2 connects to terminal 6
If the timer is still not working, go back to the breaker and test if it is delivering 240V to the circuit.
If breaker is bad on one leg, then the circuit can test with live power, but the 240V appliance will not work.
240V circuit requires both legs of 240V before circuit is complete.
Oct 24, 2010 | Intermatic EH40 - Electronic Water Heater...
I have a Generac 15kW air cooled standby generator. I have replaced the battery the spark plug the air filter the oil filter the oil. It is fueled by propane gas. All it will do is crank. Can you please...
You can check for tanks being turned off and of course if there is fuel in the tanks. If further troublshooting is necessary you should likely ask for assistance.
Sep 21, 2017 | Electrical Supplies
I have a generator with a GE 3pole 100 amp main breaker its # 1-2-3 from left to right i'm using a 10ft piece 223 alum wire to hook it to the breaker panel my problem is the panel is a 100 amp square D...
the 1 and 3 poles, the 2nd is used for more a 3phase system, hooking up say 1 and 2 wont give you 120v. test with a volt meter to confirm but if your looking for 240 you need to use 1 and 3
Nov 06, 2009 | Electrical Supplies
MY HEAT PUMP SYSTEM WILL NOT WORK IN EMERGENCY MODE
the thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2..................................................................................................w2 in airhandler to strips or w2...jumper to aux......................................................................................................................w2 in airhandler to strips.
Nov 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Briggs & Stratton 15,000 Watt Home Standby Generator Logo
42 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
