Question about Casio Exilim EX-P700 Digital Camera
My Casio P700 won't flash
I don't know what happened and i don't know why it won't flash. The Red led just keeps on blinking and i think that the flash capacitor isn't charging up... what do you think is the problem? how will i know what the problem is? can i fix it myself or just let the technicians check on it? thanks..
  • Vincent Alexei Betos Apr 03, 2007
    Hi Bogdan, thanks for the fast reply! It gave me some thoughts but still continued on checking it on my own. I've opened my camera and I checked the capacitor by connecting its ends by a screw driver. It sparked and I know that is a sign of a charge but after that... I tried to turn it on.. waited for a while, connected the ends again and.. no more spark( sign of no charge)... all of the connections were fine.. no wires were cut.. so, I just put them all back again.. and still has the same problem.. now, I don't know what to do...
    Novelist:
  • 198 Answers
Hello Betz, You are right, the flash capacitor isn't charging. The camera however doesn't have a sensor monitoring the capacitor charge, but has one on the circuits that charge the capacitor. If they aren't powered on (because of faulty connectors or damaged components) they will not be able to suply power to the inverter circuits that will charge that capacitor. The led is blinking because at some point the charging tension is sent to charging circuitry but doesn't stop blinking because charging doesn't take place or it takes place but the wires that carry the "I'm charged and ready" signal are severed or don't make a perfect electricaly contact. I don't recomand a DiY fix for this because by opening the camera you can damage the lens assembly or expose yourself to some 300-350Volts from that capacitor if it's charging. If you decide to try to diagnose yourself this problem I can suggest you to check if that capacitor is storing some tension on it, if it does, then the problem is shurely related to that "I'm charged and ready" signal wire. In either case all the connectors must be checked. Please note also that if the inverter, or charging circuitry is broken (damaged components) the service centers will change it as a whole and woun't try to repair it. This will cost about $50-$80 without labor part. Please post a reply if you nead more directions. Good luck.
Posted on Apr 03, 2007
  • Motoi  Bogdan
    Motoi Bogdan Apr 03, 2007
    This means that the defect occured after the capacitor was being charged. THe camera couldn't couple the discarge command to the actuall power inverter that needs to raise the 340V on the capacitor to the required 37000volts needed to actually fire the flash. Even if the camera couldn't charge the flash it still remained charged. A capacitor will remain charged even if you remove batteries and even after a long time.
    The bottom ideea is that somewhere among the flash circuitry you may have a broken component that may need to be changed. Integrated circuits are very difficult to test under those condition so most service centers will change the whole flash assembly for a trouble free repair.
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
Retuning Philips DTR 1500 digibox
Had same problem. Remedy is to put digibox back to factory reset. Dis-connect from mains. Keep pressing + button on front panel as you re-connect to mains. Red LED will be on, when orange LED blinks release + button. briefly press + button. You have solid red LED and blinking red LED. Enter code 9 9 0 0, by remote blinking LED will show green. Wait a few minutes and the instalation page will appear on screen. Go to update and start as you did before and C5 should be installed. Hope that helps.
Dave
Sep 30, 2009 | Philips Televison & Video
Battery will not charge
Here is how you fix the problem (without using a 9V battery method...).
The battery doesn't charge because it's been fully discharged.
What you do is you put the camera into the cradle. Now you see that the Red LED comes on solid for a while. It's charging for a few seconds. Then it starts blinking. When it does that - TAKE THE CAMERA OUT of the cradle.
Now put the camera back and repeat. Do this six or eight times. Each time what's happening is that the battery is getting a tiny bit of charge. After 8 times the LED will come on red and stay solid red.
Bingo, no problem!
Jul 10, 2008 | Casio Exilim EX-Z57 Digital Camera
Tv switched on nothing happens apart from red led flashing on front of tv help no picture or anything
Need to know the model number and also how many times is the led flashing in between pauses as the blinks are indicating an error code, But cant help without the model number and knowing how many blinks its blinking.
May 17, 2008 | Philips Televison & Video
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
CASIO EXP600 Flash problem
Hi, I sent my camera to the dealer...thanks anyway, Sevendata
Apr 09, 2008 | Casio Exilim Pro EX-P600 Digital Camera
Casio Exilim EX-Z850 Red Light Flashing
I have the same problem but could not find any solution as yet. My work around is to switch of the flash and shoot with manual controls - of course that only works well when using a tripod or someting similar. I think it is a bug with the flash loader wich seems not to give the go for shooting until flash preload is finished. If anybody has a real solution I'd be happy to read. cheers e
Sep 29, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Casio Exilim EX-P700 Digital Camera Logo
154 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
