Question about Frigidaire FEB30S5DC Electric Single Oven
CPES389AC3 - Frigidaire Gallery Oven - Element and broiler
I had a lasagna in the oven the other when I heard like a little explosion. All the lights went out in the house. When we got the electricity back up the element and broiler of the oven did not work. The stove top and lights, etc is working though. We don't know the oven that well and look for the fuses in the oven but don't know where they are, if any. We cannot find the manual.....
  • Frigidaire Master
  • 3,463 Answers
The element has blown in the oven you will need to fit a new one,and possibly the broiler one as well.
Plz rate this solution.Thanks.
Posted on Dec 24, 2008
Boiler does not work ellameny is good
Good Morning James, thanks for your post!
From my understanding your broiler feature is not working on your Frigidaire wall oven and the element is good. It could be a potential issue with the thermostat or connector of wall oven. If there is a miscommunication within the wall oven you may be able to perform a reset to clear the issues. If you would like to attempt a reset you would need to flip the household circuit breaker off for roughly ten minutes. If that does not correct your issue I would recommend contacting a professional technician for assistance in diagnosing your wall oven. Hope this is helpful. -Matt
Mar 05, 2015 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire PLEB30S8CCA baking element not working
Good Morning Jane, thank you for your post!
From what you have described, it sounds like you possibly have problem with a faulty thermal fuse, power supply board, user interface board or a communication error with the EOC (Electronic Oven Control). This is not a typical do it yourself job. Please reach out to an expert technician to ensure the appropriate replacement part(s) is ordered and is installed correctly to prevent future issues.
Best regards!
Feb 10, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire gallery series oven
Check your bottom element with ohm meter.
Oct 10, 2013 | Ovens
Oven burner and broiler burner don't warm at all. Stove top burners work. Clock display normal. When turned on lights indicate oven on and preheating (normal). I have reset the main circuit breaker with no...
Hi Brian, thank you for your post!
Sounds like the either both bake and broiler element may be faulty or a potential wiring failure to the elements. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Sep 15, 2013 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery Series Electric Oven has stopped working. I was trying to preheat the oven and after a few minutes heard a very loud pop/bang. The oven had the PF (power failure) symbol flashing and my...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 07, 2010 | Frigidaire 30 in. Electric Gallery Series...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not heating
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Jun 22, 2009 | Frigidaire 30 in. Electric Gallery Series...
My broiler element wont cool down after starting small fire in oven,, an F! beep code started but the broiler element wont cool at all.. this is a frigidaire gallery oven
It may have a grounded element. If the flame came from the element do not touch it! The only way these elements flare up is if they coma apart. The element could be going to ground from the outer case and it would feed power from the ungrounded end. turn off power and remove element. look for wire grounded too.
Mar 26, 2009 | Ovens
Frigidaire FEB30S5DC Electric Single Oven Logo
890 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
