Question about Kenwood VR-406 Receiver
One channel is out / no sound
MY YOUNG NEPHEW PLACED A 4 OHM SPEAKERINSTEAD OF AN 8 OHM SPEAKER. AFTER A SHORT TIME THE SPEAKER GOES DEAD. I LOOKED AT A SHEMATIC, THOUGHT IT MIGHT BE A POWER AMPLIFIER:IC 101(?), IC113(STK 442-090). WHAT IS THE IC101? ANY SUGGESTIONS? THANK YOU BP
Here you go.
IC101 STK412-020A HYBRID IC
Yvan
Posted on Mar 10, 2009
When i turn My Solara DSC VHF radio on it no longer beeps . I cannot hear any squelch or pick up any channels. Is this my speaker that has gone.
To test a speaker, you'll need either a digital multimeter or an analog multimeter that can read measurements of resistance (Ohms)
First isolate the speaker from the amplifier (meaning, remove the wires attached to the speaker terminals).
Set the meter to Ohms (Omega symbol).
Take the meter test leads and place each one on the speaker terminal (make sure the test leads do not touch each other)- there is no polarity to this test so it doesn't matter which test lead goes where on the speaker terminals
For an 8-Ohm rated speaker, you should get a reading of about 6-7 Ohms (approximately 15% of the speaker rating)
For a 4-Ohm speaker, around 2-3 Ohms
and for a 16-Ohm speaker, about 8-Ohms
If you can an infinite reading (make sure the test leads are not touching each other) other wise, if the test leads are not touching and you get an infinite reading, there is a short in the voice coil; speaker is defective.
OL reading on the DMM, or O Ohm resistance on analog meter, broken wire connection inside the coil= open voice coil and is defective.
If you get the proper reading on your speaker, the problem IS NOT with the speaker
Feb 24, 2017 | VHF Boating
4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Dec 09, 2007 | Audio Players & Recorders
Want to use my current speakers with a new surround sound system. Current system is 5.1 channels, rated at 100w per channel @ 8. Ohms. New System is rated 145watts, 5.2 channels at 6 Ohms. Will b ok?
Hi Ronald.
8 Ohm speakers will work just fine as replacements for the
6 ohm speakers. When fitting speakers you need to consider
The power handling capability. The impedance and the frequencies
involved. Power handling is expressed in wattage ie 100W.
Unfortunately this can be expressed in rms, max or peak music. The rms value (root mean square) is the only really relevant figure as this is the continuose handling power at 1 KHz. The impedance
is the resistance that the amp sees but is not a dc resistance and
varies with frequency. The lower the impedance the more power
will be drawn from the amp. In the event of a short circuit across
the speaker the amp will try to deliver infinite power into an infinitly
small load in an infinitesimal amount of time and will self destruct.
Using an 8 Ohm speaker draws less power than a 6 Ohm speaker.
Connecting speakers in parallel; results in the impedance beingreduced. For example two 8 Ohm speakers in parallel will result
in a 4 Ohm impedance load but in series will be 16 Ohms.
Incidentally the the .1 (5.1) is the sub woofer which only has
to handle the bass frequencies, a small percentage of the
amplifiers overall frequency response..
Connect your speakers and then power up the amp last
after double checking there are no shorts on the speaker
cables.
All the very best from Vintie.
Jan 07, 2017 | Audio Players & Recorders
My amp keeps going off after having been on for about half an hour. The top of the unit feels very hot, could it be overheating? If so, can it be fixed? Regards,
If the top is very hot, I would check the impedance on the speakers to see if any are shorted....one of them may be shorted or in a low ohm state.
Use an ohm meter and look at the speaker ratings.
If you have an 8 or 4 ohm speaker and it's reading 1 or 2 ohms, that's the problem.
Check at the speaker^s connectors if possible with the unit off but speaker connected.
If you have a dead short on any of them, disconnect and reconnect the leads at both the speaker end and the amp end.
If none are a dead short, disconnect the speakers and measure again.
the speakers should read whatever their rated impedance is.
Apr 24, 2011 | Onkyo TX-SR605 Receiver
Speaker compatibility ( Just got this new reciever with 120 volts power requirement of the receiver, but in the philippines voltage standard supply is 220. can i use 110 voltage supply instead? and I dnt...
The most likely answer is no. Unless the power transformer is of the multi tap type and has a voltage selector window on the back panel... Most speakers today have an impedance of 8 ohms. The impedance is all you need to worry about when matching speakers. You can fit 8 ohm speakers to a 4 ohm system, but you cannot fit 4 ohm speakers to an 8 ohm system. It would overload your oputput stages and cause them to fail. It's best to match 4 ohm with 4 ohm, 8 ohm with 8 ohms.etc.
Mar 19, 2010 | Audio Players & Recorders
How to turn off 'Protect"?
http://esupport.sony.com/US/perl/model-home.pl?mdl=STRDE597&LOC=3
However, If you still have the problem, there is likely damage in the receiver that needs to be corrected. I have a few other posts on this for this receiver. Make sure you don't have shorted speakers connected. One at a time, disconnect your speakers and check them with an ohm meter. If they read 8 ohms, they are electrically ok. Reconnect them to the receiver. If the read 4 or less, they are either of the wrong type or are partially or fully shorted and should be replaced with known good 8 ohm rated speakers with 100 watt program ratings.
Also, you can try using the reset to see if this provides relief. Using the front panel controls, power off. The holding down the 2 channel button, power on. You'll see a reset message on the display. If after this procedure it goes right back into protect mode, the receiver needs professional attention. Best guess is shorted outputs or other damaged components in the power amp section due to wrong type speakers connected or extended high heat operation.
Sep 11, 2009 | Sony STR-DE597 Receiver
I have a JL Audio 12 ich subwoofer rated at 8 ohms. also a mono block insignea amplifier at one ohm stable 1-4 ohms. how to i wire it safley? possible?"
Your amp based on what you say would have no problems whatsoever with an 8 ohm load, not even if it actually has dual 4 ohm coils and you wire them in parallel giving a 2 ohm load (don't know your particular sub).
Every good car amp has protection circuits to prevent itself or the speakers from damage from too low loads so it shouldn't be a problem even if you screw up with your calculations. A good amp should even be capable of dealing with a dead short on a channel, zero ohms, activating protection of course.
Good luck and don't worry!
May 26, 2009 | Jl Audio 12W0 Car Speaker
''protect'' flashed continuously -worked sporadically- seems dead
That model of receiver goes into protect mode when there is really
low
resistance or a short on your speakers/wires. It does it to protect the
final drivers in your amp. Does it do the same thing with all of your
speakers disconnected? If it doesn't then you might have a problem with
one of your speakers or wires. Check your wires for shorts in them
first. That may be the only problem. That model is designed for 8 ohm
speakers, but you can go down two 6 ohms safely. I have a STR -D865 that
has been running 6 ohm speakers safely for almost 3 years now. A way to
check your speakers out is to take an ohm-meter across the terminals on
them(with the receiver unhooked). They should read anywhere between 8
and 4 ohms. Check with the manual on your speakers to see if they
correspond. If the resistance is really low, you may have a short in
that speaker. it is also possible that if they are 4 ohm speakers, you
could have damaged the drivers in your receiver. I know the model above
mine, (the 965) has a 4-8 ohm speaker selection switch on the back. The
lower models were not designed to run 4 ohm speakers. Hopefully this has
been of some help.
Brad / Luisa_K - usenet poster
Apr 03, 2009 | Sony STR-D565 Receiver
Trying to hook up jbl sr4732 speakers the highs are to loud compaird to the bass or lows. im only using a onkio with a 100 watt per speaker.
These JBL speakers are not made for a home stereo reciever. It could be part of the problem.
I do know that they have a high frequency input and a full range input on each speaker.
I am going to guess that maybe you have them connected to the high frequency input.
Are you using 1/4 inch jacks connecting to the input of the speakers?
I don't remember these speakers having a input for wires.
You may have another issue using these speakers with that reciever.
The JBL speakers are 4 ohms each, it is very likely that the onkyo requires 8 ohm speakers.
Look on the back of the Onkyo where the speaker jacks are at and see if it says anything about the minimum impeadance.
The impeadance is the ohms. Most home recievers are not designed for anything less than 8 ohms. Some are, but most are not.
Using 4 ohm speakers on a system that requires 8 ohm speakers can cause damage to the reciever. Mostly at higher volume levels, it will cause the reciever to overheat and shut off, maybe short out a channel. It pulls 2 times the amount of current thru the output transistors as 8 ohm speakers.
Let me know if this helps you or if you need more help.
Jun 18, 2008 | Audio Players & Recorders
Multiple speakers in same outlet
How this reciever is set up is there are left and right A and left and right B Only one 8 ohm speaker should be attached per outlet. if you exceed that your driving the channel at a much lower resistance then the units designed for and the channel will burn up.. Oh it might last a short time but bet your last dollar it will burn up the channel if you over load it. Please dont forget to rate this.
Oct 15, 2006 | Pioneer VSX-454 Receiver
Kenwood VR-406 Receiver Logo
161 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
